Best ride quality lift 2" or less?
Discussion in 'Suspension' started by chays, Oct 16, 2015.
  1. Oct 16, 2015 at 4:48 AM
    chays
    chays [OP] Well-Known Member
    mississippi
    2005 tacoma dc 4x4,2012 tacoma trd ofr 4x4dc
    moto metals and more!!
    2012 trd off road 4 door
    Looking to keep ride quality as stock.
    What do you guys recommend?
    There's so many options I am confused.
    Don't wont to end up with rough ride like I did on my 2007.
    Chays
  2. Oct 16, 2015 at 4:53 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I would go with bilstein 5100 set at zero up front paired with OME 884 coils, or Eibach Coils, I thnk both coils net around 2". Out back 5100 shocks and some sort of add a leaf, progressive AAL is better than single AAL. I think the progressive AAL adds 1.5", think about if you want to level the truck, or maintain some rake.
    I did 5100 and 885 springs, got 2.75" +/-, the ride is very simliar to the offroad stock ride :thumbsup: Good luck, I am sure many more will chime in. Bought mine through Marie @HeadStrong Off-Road, great service, answers all the silly questions without judging (I think :bowdown: ) many other great vendors on here also.
    HeadStrong Off-Road and Arailt like this.
  3. Oct 16, 2015 at 5:00 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Look around and see if you can find a set of sport constant rate springs used on Craigslist and just set the front 5100 to 2". The 5100 is valve for stock springs but the TRD OR progressive springs don't work real well with the 5100. For the rear go with the above mentioned.
  4. Oct 16, 2015 at 5:06 AM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    5100 at 0 with 884 springs up front plus 1 block (plus shocks) in the back will keep same ride as stock.
  5. Oct 16, 2015 at 5:11 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    I have the 5100/884 setup and the stiffness of my front end increased considerably.
  6. Oct 16, 2015 at 5:16 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What use is the reason for the lift? Offroad or mall crawling at walmart?
  7. Oct 16, 2015 at 5:50 AM
    TACO TX
    Kelly
    Denison ,Texas
    It's worth noting that a 3 leaf progressive add a leaf in the rear will give some lift, increased load capacity while keeping good ride, eliminate axle wrap, and over all make the truck ride and handle much better. Just adding a block only excelerates the inevitable, a sagging wore out leaf pack.
    Arailt and geekhouse23 like this.
  8. Oct 16, 2015 at 6:20 AM
    RedRed
    Red
    Lake Norman NC
    Had this setup on my 12 and after springs were worn in they seemed the same as my stock SR5.... But it's just an opinion.
