Best ride quality?
Discussion in '4th Gen. Tacomas (2024+)' started by taco terror, Jun 12, 2024.
  1. Jun 12, 2024 at 6:28 AM
    taco terror
    taco terror [OP] 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I rented a 4th gen TRD OR 6’ bed, overall I very much like the truck. The only thing I’m hung up is the ride quality over small bumps. I commute a stretch of highway that is in terrible shape with about 20+ miles of cracked/buckled pavement filled in, these cracks are every 6 feet or so.
    The truck handles big bumps great, but bounces around/jiggles on these smaller bumps and leaves me with a slightly sore back after that commute.
    In short, how do the trims compare on ride over those smaller road imperfections? Perhaps the 5’ bed (the spec I would want) rides better than the 6’? Or swapping out the rear shocks may fix that jitteriness?
    I may wait to test the 2025 4Runner as I’m potentially cross shopping the two.
  2. Jun 12, 2024 at 6:45 AM
    miqie
    miqie Well-Known Member
    Off Road is supposed to have the softest suspension, Sport the firmest. Maybe adding higher profile tires to the OR and keeping them at the lowest recommended air pressure would help your commute.
    drizzoh likes this.
  3. Jun 12, 2024 at 6:50 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Drip a little air pressure
  4. Jun 12, 2024 at 6:58 AM
    taco terror
    USA
    The 4th gen seems a stiffer than the 3rd gen on those small bumps, I didn’t drive an SR5 on this highway but it seemed softer around town. I’m not sure if the OffRoad is the softest of this gen. I’m curious with the 6’ bed if it has higher spring rate rear coils.
    TRD OR has the highest profile tires and cold pressures were around 30 PSI per the door sticker.
  5. Jun 12, 2024 at 7:04 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I don't know for sure, but it may be the same suspension.
  6. Jun 12, 2024 at 7:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Unlikely. A longer wheelbase always tends to be smoother. As an extreme, think an old Caddy vs a VW bug.
    You're riding in a unladen truck, which is suspended to haul stuff, not be plush. Nice, but not plush. Put a couple hundred lbs over the rear axle and see if you like the ride better.
    If you want more plush, and need an occasional bed for HD mulch, shop a Ridgeline.
  7. Jun 12, 2024 at 8:07 AM
    Fish-r
    Fish-r New Member
    Graham
    2024 tacoma off road
    Check the air pressure when you drive one. The ones I drove had 55lbs pressure in all the tires. Much better after putting down closer to 30
  8. Jun 12, 2024 at 8:14 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    With the 4th gens I'd suspect the models with coil springs to have a more plush ride that the leaf springs. Hammer hangers will probably have a leaf spring solution in no time though.
  9. Jun 12, 2024 at 9:57 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    The front half of the 4Runner looks identical to the taco. Probably rides the same (4Runner Off-road).
    You should try a Limited or some of the other trims if possible.
  10. Jun 12, 2024 at 10:21 AM
    taco terror
    USA
    The worst highway of my drive is kinda far from the dealer so I didn’t want to put mileage on someone’s future truck. I much prefer the look of the OR but will give a Limited a longer drive once 4Runners are on the lots.
    The 4Runner is a true passenger vehicle though, so I’m anticipating more compliant suspension tuning. I love the Tacoma interior so am very glad that it’s the same. I unfortunately like the overall look of the Taco more, but the 2025 4Runner is cool. My folks had a 2016 4Runner and it was a little smoother.
    My 1st gen rides like a brick from the high spring rate coils, and I want to get out of my stiff WRX daily.
  11. Jun 12, 2024 at 10:27 AM
    CrispyTacoLover
    Very happy with the ride of all of my vehicles. Good luck.
  12. Jun 12, 2024 at 11:04 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    Mine was set to 50psi when I picked it up
  13. Jun 12, 2024 at 4:13 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Limited trim has Active Variable Suspension. Find one for a test drive.
  14. Jun 12, 2024 at 4:24 PM
    Firn
    Firn Well-Known Member
    White OR
    Shocks will likely fix that issue.
    The third gen was also criticized for a jittery tail. Shocks would help and I hear hammer hangers improved it even further.
  15. Jun 12, 2024 at 8:09 PM
    lakerman
    lakerman Well-Known Member
    1stgen taco
    The 4 runner has a shorter drivetrain, and more blocky, the first I noticed is the wind likes to push it around. Definelty more planted than a 1st gen taco, not sure of the 4th yet.
