Best rim and tire combo?
Discussion in '4 Cylinder' started by Bmeadow1, Feb 4, 2013.
  1. Feb 4, 2013 at 3:49 PM
    Bmeadow1
    Bmeadow1 [OP] Active Member
    Brogan
    Concord, NC
    2013 prerunner
    Maglites, camo seats
    Hey I've recently bought a 2013 tacoma dbl cab 4 cyl and I'm loving everything about it except the car tires they put on it. So I was wondering if y'all knew the best tire and rim size combo for it or what you put on your truck without stressing the engine too much.
    I'm trying to find something bigger than the car tires and I will eventually put on a 3in level lift on it along with the new tires.
  2. Feb 5, 2013 at 3:35 PM
    TahoeChris
    TahoeChris Well-Known Member
    South Lake Tahoe Ca
    2012 tacoma 2.7l 4x4
    OME 885 no top plate spacer OME nitro charger front and back Deaver 1.5" aal Sway bar delete
    I put SCS F5 16" wheels and 265/17 duratracs C load and that setup has the same weight as the stock setup. I do notice a little power loss going over the passes but that's 8000' and its a 4 cylinder. I'm still getting 19-21 mpgs. They will fit with stock suspension but still look good with 2"-2.5" of lift. IMO
  3. Feb 5, 2013 at 7:35 PM
    Bmeadow1
    Brogan
    Concord, NC
    2013 prerunner
    Thanks for the info and those do look pretty good on your truck
  4. Feb 5, 2013 at 10:33 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    If you run alot of highway I would suggest 235/85R16. I have Cooper AT3s in this size and in town, winter, and a quarter tank of offroading I get 20mpg. Check my pics for what they look like.
  5. Feb 10, 2013 at 4:09 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    255/85/16 BFG KM2 on 1st Gen TRDs
  6. Feb 10, 2013 at 4:38 AM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    Street, MD
    11 Tacoma TRD DCLB 4X4
    Bilstein 5100 all around with front set at .85 w/Eibach coil and 1/2 spacer, Rear 2" Deaver AAL, SCS Steath 6 matte black rims wrapped in 265/70/17 Duratracs, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 20% up front and 50% on windsheild), HID 35W 6000K headlights and 35W 4300K fog lights, Smoked Tail lights and 3rd brake light, T-Rex 2 eyelids colormatched, Foglight anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Doug Thorley LT Headers, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, Hella 700FF HID 55W 6000K behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Omega Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns
    Im running SCS Stealth 6 with 265/70/17 Duratracs. Love everything about my wheels and tires. Here is the link to SCS. This is the link to the Stealth 6 but also look at the F-5. Talk to Vin he will hook u up on rims. SCS rims are custom and a fantastic rim and very good looking.
  7. Feb 12, 2013 at 9:36 PM
    Bmeadow1
    Brogan
    Concord, NC
    2013 prerunner
    Those big tires don't hurt you going up hills on the road or hurt you gas mileage that much?
  8. Feb 12, 2013 at 9:44 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    is your truck 5 or 6 lug?
  9. Feb 12, 2013 at 11:47 PM
    4Wheelin4Banger
    Randy
    Hwy -1 to -2 MPGs if it's hilly and +1 to +2 MPGs if it's flat.
    And yes I have to drop it in 3rd for some hills, but boy are they fun off road.
  10. Feb 13, 2013 at 12:31 PM
    frrodriguez08
    frrodriguez08 Active Member
    FR
    San Antonio
    2006, 4 cyl, 4x4, Access Cab SR5
    Truck still 1400 miles away
    mine is a 06 accsses cab 4 cyl 4x4 with 96k miles 5 shift gears, 6 lugs obviously im loving it, get up to 23 ml/gl, got it last Oct. Need new tires and wheels, are thos BFG T/A's lets say 285 70/R17 too heavy for this engine?
  11. Feb 13, 2013 at 12:37 PM
    4Wheelin4Banger
    Randy
    Weight was one of several reasons I went with the skinny 33s.
    You might want to regear with that size on a 4Banger.
  12. Feb 14, 2013 at 5:22 PM
    Bmeadow1
    Brogan
    Concord, NC
    2013 prerunner
    I have the 6 lug
    If I get the skinny 235/85/16 tires would they fit on a 16x8 wheel?
  13. Feb 15, 2013 at 12:41 PM
    4Wheelin4Banger
    Randy
    :notsure:
    IMO 8" would be/look too wide for 235/85/16s.
    7" work/look good with the 255/85/16s and would be the max I'd put 235/85/16s on.
