Best roof rack options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by doyduk, Dec 13, 2020.
  1. Dec 13, 2020 at 9:27 PM
    doyduk
    doyduk [OP] New Member
    Murat
    Massachusetts
    2021 Toyota Tacoma Limited 4x4 Double Cab 5' Bed
    I'm looking for a good quality roof rail to fit Tyger TG-RK1B906B XL/68" x 41" x 8" Roof Cargo Basket for my Tacoma 2021 Limited.
    Any suggestion for this -OR- what would you put instead? I dont have top rails so I need rails first and rack for it. Amazon suggests Tyger..
    Thanks guys
  2. Dec 13, 2020 at 9:40 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    I'd go with what they recommend for sure. Nice basket tho.
    Zim
  3. Dec 13, 2020 at 10:30 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    OP, there are a number of folks here that will tell you to use the search engine. But where is the fun in that? :).
    I have a few more things to do to my truck (all pretty minor) and then I will be making a decision on the roof rack. So here are a few on my short list to get you started. Your preference will change based on budget, need, which design you like, etc. I don't know the Tyger basket but I think it will mount to most any roof bars -- which are different than a roof rack. For roof bars, you can look at Thule, Yakima and those products. Nothing wrong with a good set of roof bars, by the way.
    But see if this list helps. These are more than roof bars ... you will then have to figure out how to attach your cargo basket. That's where I would indeed use the search engine as there are a lot of creative solutions here for there.
    Tacoma OEM Roof Rack:
    https://parts.toyotaofturnersville....MIt9jmvurM7QIVxJyGCh1F5QjGEAQYAyABEgJvHvD_BwE
    Prinsu:
    https://prinsudesignstudio.com/product/2005-2019-toyota-tacoma-prinsu-cabrack/
    Uptop:
    https://www.uptopoverland.com/collections/tacoma
    Victory:
    https://www.victory4x4.com/category/ROOFRACKS.html
    Martin:
    https://martinor.com/shop/foundation-rack-1
    Cali Raised:
    https://caliraisedled.com/collections/roof-racks/products/2005-2021-toyota-tacoma-economy-roof-rack
    Front Runner:
    https://www.frontrunneroutfitters.com/en/us/roof-racks/slimline-ii-roof-rack-kits.html
    jmpell, C41n, Taco4Jaco and 11 others like this.
  4. Jan 31, 2021 at 4:30 PM
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    I'm trying to decide between the prinsu and Martin, Intel like these things are wayyy over priced tho
    averagejp likes this.
  5. Jan 31, 2021 at 4:31 PM
    YE2KA
    JB
    You're a stud for making this list for us
  6. Jan 31, 2021 at 4:32 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    I’ve seen people mount baskets onto the OEM rack. I have the factory rack and don’t even use it
    Juice Weasel likes this.
  7. Jan 31, 2021 at 4:35 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Bob K and Tacoma13_NC like this.
  8. Jan 31, 2021 at 7:26 PM
    Jpost09
    Jpost09 Well-Known Member
    2021 TRD OR 6MT
    Great list any other racks similar to the oem one?
    averagejp[QUOTED] likes this.
  9. Jan 31, 2021 at 7:28 PM
    tahoeskitaco
    tahoeskitaco Well-Known Member
    KLH
    North Tahoe
    2002 SR5 Xtra Cab + 2019 TRD OR Dbl Cab
    Stock. Custom hettich bed slide
    I've had good luck with Yakima. Sky box is good for ski trips. There stuff never seems to break.
    Malvolio and ssd2k2 like this.
  10. Jan 31, 2021 at 7:33 PM
    Jpost09
    2021 TRD OR 6MT
    I’ll check out Yakima thanks!
  11. Jan 31, 2021 at 8:38 PM
    averagejp
    Work in progress
  12. Jan 31, 2021 at 8:49 PM
    averagejp
    Work in progress
    From what I have read, there are a lot of knock offs of the OEM roof rack. Some people have them and they work just fine. Other people have them and have found the quality to be lacking. I've seen both sides but can't really confirm one way or another.
    Here is an example of an OEM roof rack for $340 (but they can be found cheaper or sometimes even used as people upgrade their roof rack to something more robust):
    https://parts.toyota.com/p/Toyota__/Roof-Rack/70290669/PT27835170.html
    Here is an example of a knock off. There are many on eBay for roughly $199:
    https://www.ebay.com/itm/Fit-Toyota...?fits=Model:Tacoma|Make:Toyota&epid=655915024
    There are some YouTube videos where people are installing these knock offs. Most of the time, they go well. I have heard sometimes the screws don't line up here and there.
    For me, the price is close enough that I would rather have the OEM rack if I go down that path ...
    Hope that helps !
  13. Jan 31, 2021 at 9:17 PM
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    Is it possible to mount an ARB awning onto an OEM roof rack?
  14. Feb 1, 2021 at 4:13 PM
    averagejp
    Work in progress
  15. Feb 1, 2021 at 4:21 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Malvolio and averagejp like this.
  16. Feb 1, 2021 at 4:48 PM
    jramey0406
    jramey0406 Member
    20 Tacoma SR
    You can make your own and save a few (hundred) bucks...1B68D45B-8F41-4627-AC07-3488028B86A8.jpg
  17. Feb 1, 2021 at 7:36 PM
    2nTaco
    2nTaco Active Member
    milky
    Palmdale,ca
    2018 TRD Sport 4x4
  18. Feb 1, 2021 at 7:47 PM
    ssd2k2
    Keith
    Minnesota
    Aluminum is easy to cut with most woodworking tools, so you just have to design and mock up the support pieces using plywood. If you have a router you can just cut the aluminum sheet by tracing the mock up piece or use a jigsaw and file all the edges to get uniform. The cross bars are a standard extruded aluminum piece and bolt to the side pieces.
    It really comes down to do you have the tools, ability to think up the design, $200 in materials, and want to spend a weekend building it. Or do you want to give a company $500 and be done with the process in 90 minutes.
  19. Feb 1, 2021 at 7:54 PM
    2nTaco
    milky
    Palmdale,ca
    2018 TRD Sport 4x4
    Cool thank you for the insight.
  20. Feb 1, 2021 at 8:55 PM
    averagejp
    Work in progress
