Best roof top tent against the elements?
Discussion in 'Product Reviews' started by allday, Sep 30, 2017.
Which brand is your favorite?
  1. CVT
    7 vote(s)
    23.3%
  2. Tepui
    7 vote(s)
    23.3%
  3. Go FSR
    6 vote(s)
    20.0%
  4. Something Else - comment below please
    10 vote(s)
    33.3%
  1. Sep 30, 2017 at 2:52 AM
    allday
    allday [OP] Active Member
    Aaron
    Los Angeles, CA
    2017 Cement TRD PRO
    Hey TW, so it’s 2:48am in Santa Barbara, CA and I’m wide awake because it just happens to be the windiest night I’ve ever experienced camping...
    I’m staring at my tent ceiling, and I’ve already had to replace several stakes because the wind has been so annoying, it’s actually removed some ties from the ground.
    I’ve been skeptical to purchasing a roof top tent, but after tonight, I think I’m sold on a RTT.
    Okay, so my question is — which is the best RTT for heavy winds, rain? Snow? Etc.
    Not sure if there’s a thread already for this, but any help would definitely be appreciated.
    Thanks guys and gals...
  2. Oct 2, 2017 at 6:24 PM
    Tacoma HEART
    Tacoma HEART - - - - - - -
    Sam
    AA CO
    '14 DCSB TRD S Black
    Yawn...
    This has been my question for the longest time.
    *interested in the result.
    allday[OP] likes this.
  3. Oct 17, 2017 at 4:27 PM
    spikemd
    spikemd Member
    The Overland Pros Anza tent zips up completely so there is no extra material to flap in the wind. I have had a Tuff Stuff Overland tent with the overhang and now the Overland Pros. If the wind is strong enough, it can lift the Tuff Stuff overhang off the ground! In wind, the Overland Pros is solid and is not effected. If it is really windy, I take the rain fly off as I find it can catch the wind and flap. Obviously the fly will help if it is raining.20170919_073524~2.jpg 20170921_093027-1.jpg
    Tacoma HEART likes this.
  4. Dec 12, 2017 at 7:04 PM
    frusteri4
    frusteri4 Well-Known Member
    Reno
    off road ACLB
    Pelfrey Front, CVT tiny, OME heavy,
    I have a CVT mt. Batchelor (old mt. bailey but the same tent) with a weather hood and I have spent probably 70 ish nights in it.
    I have had a lot of thoughts about the tent holding up to the elements so here goes:
    1. The bars in some soft-shell tents that I have seen are like a 5/8” aluminum (tuff-stuff, smittybilt, etc). The bars in the tepui and CVT tents are a full 1”. Now I’m no engineer but it would seem that bigger bars = stronger bars
    2. Soft-shell tents range in width. Again only my uneducated observation, but a larger span is going to
    A. Collect more precipitation (weight)
    B. Be a bigger sail in the wind essentially
    3. Weather hoods are partially misinterpreted. When I got mine I read the advertisement and how it praised the “thermal reflective properties”. However when I put it on I noticed a few other traits
    A. Completely impervious to rain but probably the most important observation was
    B. Dead air space (insulation). The first time I slept in my tent with the weather hood I was blown away not only was it warmer in cold weather, but it stayed cooler on hot hungover summer mornings. And since my breath wasn’t hitting a cold 1 layer inside of a tent and turning into condensation like the side of a cold Coors light (I know they’re cold because the mountains are blue) it was much less stuffy. Lastly: 2 layers of material deaden the outside sound. Putting the weather hood on my tent made it feel less like a tent, and more like a camper.
    4. Wind. I stayed in my little tent in a snow storm at above 8200’ elevation last winter just to see how it would do. Even with the weather hood on and not much to flap around, it did flap a little and the weather hood doors started to open up (I still need to sew on some buckles for this winter to keep the doors closed in high winds). The tent also started to lift up and start closing on me at one point :crapstorm::eek:. I should probably use a dirt bike strap to hold my flip out to my bed rail.
    5. Ruggedized/summit models/more expensive tent. Better stronger parts duh!
    It really just depends on your budget so IMHO here are my suggestions:
    $1000ish range:
    Tepui Ayer or CVT mt.Batchelor with weather hood, buckles on weather hood and flip out anchored to something. Cheap but also a little cramped
    $2000ish
    CVT Shasta sierra model or Tepui Kukenam rugedized with the same modifications as mentioned above. Good all around well built tents, that offer a little more room inside.
    $$$$$is no option:
    At just under $4000 Alu-Cab expedition tents are bad ass. It has plug-ins for your electric blanket, can be completely rigid with the use of a bar to keep the struts from closing due to wind or snow (triangles are super strong right?). Probably sheds some snow, and can be faced into the wind. Doesn’t have to fold up so has more volume for thicker sleeping bags small air volume inside but about 3” wider than my CVT.
    I’d probably take the fabric portion to an upholstery shop and have a second layer sewn in for that insulating effect I mentioned earlier, and have a boat window/escape hatch installed under where this guy has his max tracks. And some solar panels bellow it to trickle charge a dual battery setup, to keep my electric blanket chugging all night long.
    Did I just get carried away?
  5. Jan 14, 2018 at 2:55 PM
    Hal9001
    Hal9001 Well-Known Member
    thanks for this. I've been looking at Tepui Kukenam but I'll also check out CVT Shasta now as well.
    frusteri4 likes this.
  6. Jan 17, 2018 at 2:49 PM
    frusteri4
    Reno
    off road ACLB
    If you’re going to go with the traditional style, and you’re already going to drop a couple thousand, I hear The South African ones are pretty dang sturdy
  7. Sep 28, 2018 at 6:18 PM
    Easy_rider
    Easy_rider Well-Known Member
    VA Beach
    15 TRD PRO
    2" AAL Tint Yellow fogs Ultra gauge Egr rain guards ARE shell Bed mat HID low/high 32'' stealth LED light bar LED bed lights 6'' Led side lights coverking seat covers head rest screen/DVD player CB radio Homemade CB antenna bed bracket Diff breather mod Custom camper shell rack On board air Master Air Relocated hitch plug Homemade Shell rack Rear seat USB plug Jerry can pressurized with hose attached Blue sea fuse block under hood with 80amp breaker All dash light WHITE LED converted
    Roof Nest!
