Best route for low end torque?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikeypainter, Dec 13, 2018.
  1. Dec 14, 2018 at 12:11 PM
    #41
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    “Supercharged” key word
  2. Dec 14, 2018 at 12:21 PM
    #42
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Yep an engine is basically gas powered air pump so the more air you can stuff in then push out efficiently you'll make more hp !!
  3. Dec 14, 2018 at 12:21 PM
    #43
    Muddinfun
    Muddinfun Well-Known Member
    You can also have multiple sets of tires for whatever you want to do. For my mudding Ford, I have highway tires and comp cut Boggers. For my Taco, I have Duratracs on TRD fake beadlock wheels for everyday driving, Toyos on 1st gen aluminum wheels for playing in the mud, and studded snow tires on TRD OR wheels for if the weatherman predicts ice. This way, if I bonk a rock or curb, I haven't destroyed a $225 TRD wheel.
    Clearwater Bill likes this.
  4. Dec 14, 2018 at 12:24 PM
    #44
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
  5. Dec 14, 2018 at 12:31 PM
    #45
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Gear that shit down. Look at the 4.88 or 5.13 (not sure if that gear is available for the tacoma) gears.. My tacoma was the same way with much smaller tires than yours. She had no grunt for hills or larger obstacles. I now have a jeep that had the same issue and geared down to 4.88 and its a monster, especially in 4lo. I did have to sacrifice some fuel efficiency because at 75mph I am now running barely over 3k rpms.. so its no longer a highway vehicle if im traveling.
    Supercharging the 2.7 is another option but that does put some significant strain on the internals, especially if you have a heavy foot. Maybe im wrong.. its been a few years since ive owned a tacoma.
    mikeypainter[OP] likes this.
  6. Dec 14, 2018 at 12:45 PM
    #46
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    My old Jeep a 68 M38A1 had a Buick V6 ,GM465 1 ton 4spd with 6 54:1 first gear , Dana 18 t/case with 3.50:1gearing and axles with 5.38gears and also had a Warn overdrive with 15%reduction
    Overall gearing was 128.1:1 in low range and going down hills if I wasn't touching the throttle it wouldn't move . In 1rst gear It was 3k rpm at 10mph
  7. Dec 14, 2018 at 12:46 PM
    #47
    austin2009
    Austin
    Boise, Idaho
    I could be wrong, but I believe the 3RZ and the 2TR both are forged internals. Along with the cast iron blocks. So boost should be fine
  8. Dec 14, 2018 at 12:50 PM
    #48
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I'm running a TRD supercharger on my 3RZ either 4.5 psi or 8.5 psi and just running big "pink" Supra injectors and have had no problems in the 14 years the supercharger has been on my truck . Current mileage is 69k miles
    austin2009[QUOTED] likes this.
  9. Dec 14, 2018 at 1:05 PM
    #49
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Cool cool like I said. It’s been a while since I’ve owned a taco so I’m not super up to date
  10. Dec 14, 2018 at 3:03 PM
    #50
    Pigpen
    Dan
    Northwest Montana
    Once you discover how great 4 low is, get in touch with @Up2NoGood and buy his plug and play kit for 2 wheel drive low. It should come as a stock feature on these trucks. I use mine all the time.
    Muddinfun and mikeypainter[OP] like this.
  11. Dec 17, 2018 at 9:20 AM
    #51
    96carboard
    96carboard Well-Known Member
    Please do take a little peek at the torque curve from dyno charts and not just the point referenced by the spec. This 2.7, while it does make marginally higher torque at about 3800, makes a very flat and very even torque all the way from about 1500-5500 rpm. THIS ENGINE LOVES TO RUN AT 2K!
    Woofer2609 likes this.
  12. Dec 17, 2018 at 9:47 AM
    #52
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    This is better info than the spec for sure! The graph deviates from the spec heavily look at peak torque RPM compared to spec. It is still a little more happy with more RPM meaning that a gear change still is complimentary wouldn't you agree?
  13. Dec 17, 2018 at 10:13 AM
    #53
    96carboard
    A few things;
    1) That chart actually compares a stock with a minor modification. The BLUE line is stock.
    2) A gear change will always increase torque in a linear manner. This is a separate point however. The main thing to keep in mind is that you don't need to wind the engine out for the sake of getting more torque in the same gear. You can go slower and get nearly the same torque.
    3) That dyno chart is also wheel dyno, whereas spec is crank dyno.
  14. Dec 17, 2018 at 10:27 AM
    #54
    13yota
    13yota Well-Known Member
    Colorado
    2013 2.7 single cab 4x4
    Regear will help a ton. I have the same truck, 488’s were a huge change. I have lightweight and smaller tires than you so it won't be quite as nice, but by far the best upgrade I’ve done drivability wise.
  15. Dec 17, 2018 at 11:14 AM
    #55
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    4.88s
    b_r_o likes this.
