Best ScanGauge Calibration Technique for accurate MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davatk, Jan 21, 2009.
  1. Jan 21, 2009 at 4:13 AM
    davatk
    davatk [OP] Well-Known Member
    Northwestern Virginia
    2009 DC TRD Sport Long Bed
    Tube Steps, Hood Deflector, ScanGauage, GPS
    Hello all,
    I have had my scanguage for a while and at one time thought I had it calibrated pretty well, but then started trying to "top off" the tank and compare actual gallons used against what the scan guage stated and it does not seem to be that accurate any more. I wonder if it's winter gas (oxygenated) causing me to not be able to fully fill the tank. Seems that sometimes I can get a lot in after the first "click" of the nozzle, other times only a half gallon or so. I wonder if it's best just to do a slow fill till it hits the first click, then not try to fill it any more. The only thing about that is, that there are always different flow rates at different pumps, and slopes, so I figured topping it off would be the best way to get a consistent figure.
    Anyhow, I'm curious how other ScanGauge owners have been calibrating theirs, and the easiest way to keep it calibrated - in other words suppose I decide to put in $10.00 instead of a complete fill, what would be the best thing to do then ?
    Thanks !
  2. Jan 21, 2009 at 5:22 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    I've found that following the book has worked out very well for me. i.e. same gas station, same pump, no more fill after the first click "off". I still do not have a good technique for only putting $10 or so in and not filling it up so I just fill it up every time.
  3. Jan 21, 2009 at 6:15 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    +1
    Different pumps will stop at slightly different fill levels.
    It's my understanding that on modern sealed fueling systems there is a return that's supposed to draw away the fumes from your tank as you fill to keep them from escaping into the atmosphere which is why you don't smell the gas when filling like we used to in the "good old days". The reason you're not supposed to top off the tank after the pump stops is that if you keep squeezing the handle the return system will end up sucking up fuel along with the fumes.
  4. Jan 21, 2009 at 8:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    Especially...do not over-fill after that click!
    Adjust the gallons on the pump versus what the scangauge is telling you (what it thinks you used - fillup screen).
    Don't top off so much. Sometimes I think the Scangauge can't get 'settled' (so to speak) if you're constantly resetting the information when topping off. Let it go for an entire tank....several tankfulls....
  5. Apr 26, 2010 at 9:03 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Hey what did everyone set their scan guage to for setup>speed 0% with 285s? Thanks in advance
  6. Apr 26, 2010 at 9:10 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Just get going at 60 mph on a the freeway according to the SG. Then at a mile marker, start a stop watch. stop the watch when you hit the next marker. The amount the number differs from 1 minute is your percentage.
  7. Apr 26, 2010 at 9:17 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    I use +7% for figuring out Odometer diff mpg when gasing up does that sound right? Somebody must be using around this number right?
  8. Apr 28, 2010 at 6:22 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Bump - looking for speed adjustment % for 285s?
  9. Apr 28, 2010 at 7:45 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    When I do a fillup I enter how many gallons I put In the tank on the SG, I.e. 17.1 or so. It has been pretty accurate. Don't fill anymore past the initial click when the pump stops. As for bigger tires I increased mine to 6%. If my speedo is at 60 I'm really going 64. I used my gps for this. This also changes how many miles you are actually getting out of a tank, my odo on the truck said 286, the SG said I had like 298.
  10. Apr 28, 2010 at 7:52 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Thanks Keason.. that is what I was looking for. I'm just getting used to my new Scangauge. At first I wasn't too impressed but its starting to grow on me. I'll leave 7% for now. Going into winter I want to experiment with a Hot air intake to improve MPG in this Frozen Tundra I live in 6 months out of the year :)
  11. Apr 28, 2010 at 9:33 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    "hot air intake" ?
    why?
  12. Apr 28, 2010 at 9:35 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    To improve MPG, its a hypermiling thing. Basically I want to hack a stock intake (a spare of course) and make it pull air from right above the header, or close to the engine. The burn is more efficient, air temp is warmer and thus better mpg so they say..
  13. Apr 28, 2010 at 9:39 AM
    pfatyol
    pfatyol Well-Known Member
    Patrick
    Southcoast MA & lakes region NH
    2010 DC Sport
    American Roll cover, fog light mod, weather tech, marathon seat covers, twin booster seats.
    I think it is because, Hot air is less dense and a result the computer will adjust the fuel at a particular throttle position down so that the air to fuel mix is still correct. Less power but less fuel used at the same RPM setting. It's is the reason why MPG drops in the winter, cold air is denser which equals more fuel required for the proper air fuel mix.
    A few more details:
    ideal air to fuel mix is 14.7 lbs air to 1 lb gas - I have no idea what they set the range around this ideal to be, in the engine's ECU.
    Air at sea level 10 degree F is about .084 lb/ft3
    Air at sea level 90 degree F is about .0781 lb/ft3
    so this 80 degree change has about 15% decrease in actual air going into the cylinder. If the computer did not adjust the fuel being injected the engine would be way rich - resulting in some bad emissions.
    There are other items also being monitored and adjusted for: pressure, humidity etc. all which feed into the proper amount of fuel to inject.
  14. Apr 28, 2010 at 9:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Hmmm thats interesting
  15. Apr 28, 2010 at 10:34 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Yep that's it. I'll post up how it goes...first thing is to understand the baselines on the Scanguage and go from there.
  16. Apr 28, 2010 at 12:04 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    there are people on here selling stock intakes from time to time for pretty cheap that you could experiment with
