best seller toytec 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tnj, Aug 6, 2010.
  1. Aug 6, 2010 at 9:11 AM
    tnj
    tnj [OP] Well-Known Member
    tom and jane
    CO
    2007 tacoma 4x4 off road 6speed
    13"antennax,black painted grill,hammered black paint on rims,debadged,3" toytec lift,aal,884 coils with top plate,diff. drop,custom grill,6 speed trans, painted engine cover
    thinking of getting this one at the end of the month,does anyone have this one which includes add a leafs for the back and coil springs and spacers for the front?thanks
  2. Aug 6, 2010 at 9:35 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Aug 6, 2010 at 9:38 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I believe you need rear shocks to accommodate the lift, and new ones in the front wouldn't be a bad idea either.
  4. Aug 9, 2010 at 7:36 AM
    tnj
    tom and jane
    CO
    ok,i will do more research unless someone else knows?
  5. Aug 9, 2010 at 7:49 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    new shocks are not needed, but recommend. uca's are also recommended when going over 3"
  6. Aug 9, 2010 at 7:53 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    You can also get rear shock extenders to use your stock shocks if you don't want new rear shocks.
  7. Aug 9, 2010 at 7:54 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    I believe I have this Kit. OME 881 coils up front with a 2 inch spacer and 1in top plate. You can use the stock shocks
    You will need the pro comp extended shocks for the rear.
    It's a lil stiff up front but I'm used to it.
    And for Gods sake get it alligned directly afterwards or it will chew up and spit out your front bearings.
    Call and ask for Ben. He will hook you up.
  8. Aug 9, 2010 at 8:00 AM
    tnj
    tom and jane
    CO
    i talked to toytec and he recommend but dont have to,thanks for the advice
  9. Aug 9, 2010 at 8:27 AM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    toytec says that the lift will not fit toyota's with five lug.ok i'm lost could someone explain--thank you
    later tig1:confused:
  10. Aug 9, 2010 at 8:29 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    5 lugs have totally different set-up in the front. They don't use the same coil overs.
  11. Aug 9, 2010 at 8:32 AM
    tig1
    Paul
    2009 tacoma
    ok now I get it. got to go lunch is over.thanks
    later tig1
  12. Aug 9, 2010 at 8:58 AM
    vicstacoma
    vicstacoma Well-Known Member
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Air raid cold air intake, procomp 7089 16x8 wheels, bf goodrich all terrain ko 265/75r16. Toytec 3" lift kit. Power slot rotors with posiquiet ceramics pads. Diff breather mod. LR Upper Control Arms.
    I have this kit on my first gen, but I also got the rear shocks, differential drop kit, and brake proportioning valve. My alignment was never right after i installed all this so I bought some LR upper control arms from toytec as well and what a difference. Now my truck goes straight and I get no vibrations at all! I would look into getting all this together if i were you and just find the discount code here on tacomaworld and you might get a good deal.
  13. Aug 9, 2010 at 9:02 AM
    tnj
    tom and jane
    CO
    what are uca's?
  14. Aug 9, 2010 at 9:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    UCA = Upper Control Arms
  15. Aug 9, 2010 at 9:09 AM
    vicstacoma
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Upper control arms are needed if you get a lift of 3" or more in most cases. The ones toytec sells are adjustable where there are -2 degrees of caster built in to correct for lifting the truck.
