Best setting for snow/ice
Discussion in 'Off-Roading & Trails' started by DELTADUX, Dec 24, 2020.
  1. Dec 24, 2020 at 4:02 PM
    DELTADUX
    DELTADUX [OP] Member
    2015 trd off road
    Have a 2015 Tacoma TRD off-road 4x4. what are the best settings possible for driving in ice and/or snow. Driving on paved roads and gravel, no “off roading”.
    thanks
  2. Dec 24, 2020 at 4:05 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Normal 4 hi
  3. Dec 24, 2020 at 4:15 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    4hi on snow/ice. If the snow/ice is patchy with sections of clear pavement only use 4X4 as needed to get moving. Never on clear pavement, not even on wet pavement. One possible exception would be pulling a boat out of the water on a wet boat launch. But shift out of 4X4 ASAP after you get it out of the water. 4x4 is OK on gravel or any loose road surface such as sand, loose dirt, grass, mud, even grass.
    Lo range just reduces the gear ratios in the transmission by about 2.5X. It is for those times when using 4X4 and more torque is needed for pulling in deep sand or creeping slowly over rough terrain. Great for creeping slowly down steep hills off road without having to use brakes.
  4. Dec 28, 2020 at 11:18 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Don't get bogged down in what "setting" you need. Aside from 4x4 and a set of chains, there's really nothing special about driving in snow vs. any other low traction situation.
    We've been doing it for generations without buttons and settings.
    The "best setting possible" is the one behind the wheel.
  5. Dec 28, 2020 at 11:21 AM
    jbrandt
    Justin
    Dude, the truck's not going to explode if you drive it in 4x4.
    Especially in the rain, I drive around on pavement in 4x4 all the time.
    Only time you'd ever notice is trying to make a tight U-turn in a parking lot. If your truck can't handle that, don't ever go off-roading with it.
    llamasmurf likes this.
