Best shocks for 2nd gen Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blade29, Nov 23, 2024.
  1. Nov 23, 2024 at 1:05 AM
    Blade29
    Blade29 [OP] Member
    Blake
    2011 Tacoma TRD Off Road
    Im thinking of replacing OEM shocks with aftermarket’s. Any suggestions that will give my truck a 2-2.5 inch lift and decrease the rake? I want to fit larger tires on it as well.
  2. Nov 23, 2024 at 2:19 AM
    Mack83
    Mack83 Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    I’d recommend checking out Bilstein 5100s or Fox 2.0 shocks. I’ve had good luck with the Bilsteins on my truck—they give a solid 2-2.5 inch lift and handle rougher roads well, plus they helped with the rake. If you're planning to run bigger tires, you might also want to consider a leveling kit to get the stance just right. Just make sure the shocks and kit are compatible with your truck’s setup for the best results.
  3. Nov 23, 2024 at 5:47 AM
    stallion85
    stallion85 Member
    Jefferson
    Cedar City
    TRD 4x4
    2" Lift, Kings, Sliders, Bumpers, Winch, Skids, BFG Ko's, Clazzio's leather with heated seats, LED lighting
    Kings are King. If you want performance and a comfortable ride look no further.
