Best shocks for gravel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFrank, Dec 10, 2016.
  1. Dec 10, 2016 at 11:32 AM
    TacoFrank
    TacoFrank [OP] Member
    Frank
    2011 Toyota Tacoma access cab 2x4 sr5
    Good day. I have a 2011 Toyota Tacoma access cab 2x4 with 80k km. Original shocks. I'm looking to change to a shock that's good for the gravel roads I travel on. I would like to firm up the ride a bit and raise the suspension without a lift kit. Any good suggestions?
    Appreciated.
  2. Dec 10, 2016 at 11:33 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You'll have a hard time raising the suspension without a lift kit.
    I also assume you're talking about washboard gravel roads?
    What's your budget?
  3. Dec 10, 2016 at 11:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not gonna happen.
    Is your 'lift' for looks or function?
  4. Dec 10, 2016 at 11:41 AM
    TacoFrank
    Frank
    Washboard, loose gravel, rocks, mud, snow, snow drifts, ice. Just all around Canadian driving conditions. Budget? Best value for the buck to be considered. Lift is not necessary but thought spring overs might do a bit?
  5. Dec 10, 2016 at 11:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    You already have coil overs in the front, leaf in the back. Shocks don't lift (or lower), they control spring ocillation.
    If you are thinking of 5100s, those are used for cheap lift via preloading the OE spring when you use one of the optional spring perches. Not the choice you want for your conditions. They can be used with stiffer aftermarket springs and 0 perch to gain lift that way. You need to be careful though. You don't want too stiff, you just need control for your conditions.
    Suggest you contact Marie @HeadStrong Off-Road. Share your driving conditions and let them recommend a package. If it's more than you thought you'd spend, just keep saving till you can afford it. Do it once, do it right.
    timbobzimbob likes this.
  6. Dec 10, 2016 at 11:48 AM
    T4RFTMFW
    Budget is important to actually help you out.
    The cost of suspension components ranges from $50-2k+ in US dollars. So it's pretty important to the topic.
  7. Dec 10, 2016 at 11:51 AM
    TacoFrank
    Frank
    Hmmm... Got me thinking. I wanted to lift 2 to 3" to keep the snow from packing in the underbelly so much. Lift kits aren't cheap and hard to install with minimal tooling. Guess I will stick with good quality shocks. Recommendations?
  8. Dec 10, 2016 at 11:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    HeadStrong Off-Road likes this.
  9. Dec 10, 2016 at 11:53 AM
    T4RFTMFW
    $500 US is a basic lift. Not expensive and is 2" +/- and can be installed with $20 in hand tools.
    Depends on that budget, again.
  10. Dec 10, 2016 at 11:55 AM
    TacoFrank
    Frank
    Budgetwise I was thinking around 500 to 600 CDN.
  11. Dec 10, 2016 at 11:59 AM
    TacoFrank
    Frank
    Thanks for the info. First time in this forum. I like it.
  12. Dec 10, 2016 at 12:03 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Soooo $13 U.S :evil:
    Sounds like 5100's are right up your alley.
    StevoNB likes this.
  13. Dec 10, 2016 at 1:14 PM
    ShawnR
    ShawnR Roads?? We don't need no stinkin' roads...
    Shawn
    Denver
    10 Taco TRD OR access cab
    PIAA driving lights,Pioneer AVH-P3300BT stereo with HD radio and Axxess steering wheel control adapter,rearview mirror mod,ReTrax rolling cover,Demello front bumper,WeatherTech,10 inch woofer,500 watt amp,CB in armrest, heated Wet Okole seat covers,Spidertrax spacers, ARB twin compressor,Ikon 10,500lb wireless winch,A-pillar RAM mount,Pull-Pal,electric locking tailgate
    Someone recommended Icon Stage 1's to help on washboards, but its $1000+.
    Suspensions are not cheap.
