Best shocks for my 2002 Taco 2.4l
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bahmi, Sep 15, 2018.
  1. Sep 15, 2018 at 4:38 PM
    Bahmi
    Bahmi [OP] Active Member
    2000 Tacoma 2.4 auto
    If you had only enough dough to buy 2 shocks, would you put them on the front OR the back? Thinking of trying a pair on the rear at present.
  2. Sep 16, 2018 at 4:26 AM
    RonJon31
    RonJon31 Well-Known Member
    Ronnie
    Alaska
    04 Single Cab Tacoma PreRunner
    5100s 265/75/16 Wildpeaks
    I'd save the money for a full set, but if I absolutely had to pick I'd have to guess the front
  3. Sep 16, 2018 at 7:24 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    KYB gas-a-just. I think you can get them from most parts stores such as AutoZone. No need to fork over the money for Bilsteins on a 5 lugger.
    Edit: All the parts stores are running their ShockTober sales. Good deals on KYB, Monroe, Gabriel etc.
    Steves104x4 likes this.
  4. Sep 16, 2018 at 3:56 PM
    jimmyjoebob
    jimmyjoebob New Member
    03 taco extra cab
    agree with the KYB gas-a just...installed recently....rears no prob. install.
    Fronts....before you start get one of the lwr mount bolts slightly longer than the factory installed bolts, to be used as a tool to help with install.
    when installing the new shock , use this longer bolt to pull the extended shock up to where the other mount bolt can then be threaded in and started, then you can remove the longer bolt, and reinstall the factory length bolt.
    the job can be done without this longer bolt , but it will save a lot of swearing and jack fiddling
    Oh and I got mine from Amazon
  5. Sep 17, 2018 at 12:37 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Don't buy two. The end with the old shocks will cause the new end to bounce and wear out the new shocks. Buy 4.
  6. Sep 17, 2018 at 1:06 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Obviously you'll bet "better" shocks if you only buy two, but there's a pretty big price gap between "decent" shocks and "really nice" shocks. A set of 5100s or the OME nitro chargers will run you $350 for a set of 4, but there really aren't that many shocks (none that I can think of) that are a *significant* improvement over the 5100s if you only bought 2 at that same price.
    Next jump in shocks is going to be some adjustable billstien coilovers, Kings, Icons, Fox. That'll run you at least $800-1000 or more for a pair.
    I got a set of extended travel Kings for the front my my truck, still running older 5100s in the rear. My Kings ran $1000+ for two, then of course I ended up with uniball UCAs too, for another $700 on top of that.
    I chose to set up my front suspension first, then when funds were available, set up the rear. Not ideal, but it's not like it's undrivable.
    So, if your budget is less than ~$500, IMO don't bother with "only getting 2" to get better shocks, just get the full set of the 5100's or OMEs. But if your budget is a grand or more, you probably aren't looking at the 5100s anyway, lol.
  7. Sep 17, 2018 at 1:10 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Get the KYB’s and call it a day
  8. Sep 17, 2018 at 4:25 PM
    jimmyjoebob
    03 taco extra cab
    Agreed I got all 4 for $120 on Amazon and a $40 rebate.................they work fine
    But with less bragging rights, I suppose
    Steves104x4[QUOTED] likes this.
