Best shop to do wheel alignment East Bay California
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco dv, Mar 2, 2025.
  1. Mar 2, 2025 at 9:14 PM
    Taco dv
    Taco dv [OP] Well-Known Member
    2020 Tacoma TRD off-road
    Any recommendations on the best trusted shop to do my wheel alignment after installing 2” TRD lift kit? Located in the East Bay Area. Brentwood, Oakley, Livermore, or willing to drive anywhere in the Bay Area to find someone to do it right the first time. Thanks.
  2. Mar 2, 2025 at 10:12 PM
    mauropotiguar
    mauropotiguar New Member
    2022 Tacoma TRD OR
    I had mine done at 4wheel Parts in Oakland. No other shop was able to get it right. I have 2.5in lift. Only shop open on Saturdays as well.
    Taco dv[OP] likes this.
  3. Mar 2, 2025 at 10:42 PM
    StreetSr5
    StreetSr5 Well-Known Member
    Fairfield is probably out of your range but “Alignment Shop” in Fairfield is by far the best shop I’ve been to. It’s ran by 1 older, knowledgeable man who’s been doing alignments for over 30 years, so it’s not like it’ll be a coin toss that you’ll get a good tech. He’s aligned my lifted/aftermarket uca truck 3 times just because I wanted to try out different numbers and he’ll do anything you ask him to do as long as it’s possible. It’s easy to schedule an appointment, and you’re in there and out in less than an hour every time. 85 dollars for a FULL alignment, no overpriced toe and goes with inexperienced techs like other shops. Can’t recommend him enough.
    Taco dv[OP] and dirt clod like this.
  4. Mar 3, 2025 at 8:20 AM
    guest_707
    guest_707 Well-Known Member
    I took mine to Beep's Offroad in Hayward. I have 255/85r16 tires with OME uca and the tires were running against the back fender area. The ship that installed the arms aligned it to factory specs and I went back twice to ask for more caster (3.5+). They barely got it past 3 degrees each time. Took it to a shop in Santa Rosa and the gentleman got one side to 3.5 and the other pretty close, around 3.4 and I thought it was fine but it ended up rubbing when I turned into my driveway. After nearly a year of that, I finally stopped putting it off and drove my ass down to Beep's and they did an amazing job. When the guy was checking me in for the alignment, he asked me why I drove 60 miles to get an alignment and I told him because people recommended them. He also warned me the OMEs were likely at their limit so they may not be able to get too much caster but ended up calling me an hour later telling me one of the alignment tabs was bent (forgot what he said exactly) but he even sent me a video of what was bent and said that's likely why no one else has been able or willing to align it too far past factory specs. He asked for approval to try to work around the bent tab, and got it way better than I expected. My caster is sitting at a juicy 4.5 now and maybe it's a placebo but the truck feels like it tracks better on the highway now, and best of all, no rubbing detected so far (haven't had a chance to off road yet).
    FunknNasty likes this.
  5. Mar 3, 2025 at 8:42 AM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    I had good experience with Auto Innovations in Milpitas, CA
    EDDO and FunknNasty like this.
  6. Mar 3, 2025 at 9:28 AM
    Zula
    Zula Active Member
    Lance
    2019 TRD OR LB
    2" Eibach lift ,285's
    +2 Auto Innovatons in Milpitas. Does all of Milogen's alignments and they know what you're looking for.
  7. Mar 3, 2025 at 9:32 AM
    Taco dv
    If you don’t mind me asking, what or who is Milogen?
  8. Mar 3, 2025 at 9:44 AM
    Zula
    Zula Active Member
    Lance
    2019 TRD OR LB
    He's a fabricator in Milpitas that works on tons of Tacomas. I had him do my CMC and he took my truck over to Auto Innovations to do my alignment. Awesome job on the CMC and then the alignment shop got me 4 degrees of caster to clear my bigger tires.
  9. Mar 3, 2025 at 9:55 AM
    Taco dv
    Are you using your stock UCA”s with 4 degree caster?
  10. Mar 3, 2025 at 10:19 AM
    Zula
    Zula Active Member
    Lance
    2019 TRD OR LB
    No, I'm running some Poly Performance UCA's.
