Best size rim on 3 inch lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zach faf, Apr 26, 2014.
  1. Apr 26, 2014 at 12:08 PM
    Zach faf
    Zach faf [OP] Member
    Zach
    Virginia
    03 tacoma trd
    Have a 03 tacoma extra cab about to lift it 3inchs and I'm trying to figure out the best wheel size with 285/75/16 tires. Any suggestions on width,offset and back spacing?
  2. Apr 26, 2014 at 12:11 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Depends on what you want really.
    For width you can get away with anything from 7"-10". I'd recommend 8" for the best at holding the bead.
    For backspacing I wouldn't do anything more than 4". I have 3.75" and my 12.5" wide tires just barely stick out past the flares.
  3. Apr 26, 2014 at 12:37 PM
    Zach faf
    Zach
    Virginia
    03 tacoma trd
    So smaller bs equals sticking out further ? I'm looking at a 16 by 8 rim with 4 in bs with a 12mm offset what would that do with a 285/75/16 with 3 in lift?
  4. Apr 26, 2014 at 12:40 PM
    Zach faf
    Zach
    Virginia
    03 tacoma trd
    Your truck is sick btw ! Do u like the lift and do ur 33 12.5 rub?
  5. Apr 26, 2014 at 12:44 PM
    PcBuilder14
    Brent
    Nor Cal
    Yup, the smaller the backspacing the closer the lip on the back of the wheel is to the hub.
    With that wheel you're looking at you shouldn't have any issues with it fitting, but with 4" backspacing you may rub the frame just slightly at full turn.
    Thanks.
    Yeah, my tires rub, so I had to trim some.
    Really almost any tire that is 32" or larger and will see full suspension travel will require you to trim some.
    http://www.expeditionswest.com/equipment/tacoma/bfg_mt_km.html
  6. Apr 26, 2014 at 1:11 PM
    Zach faf
    Zach
    Virginia
    03 tacoma trd
    My goal I to not have to mess with the pinch welds just trim a little under full turn what would u suggest with the 3 inch susp lift
  7. Apr 26, 2014 at 1:13 PM
    Zach faf
    Zach
    Virginia
    03 tacoma trd
    Just want to figure out wheel and tire combo that will work good and look good maybe just barely stick out past flares
  8. Apr 26, 2014 at 4:44 PM
    PcBuilder14
    Brent
    Nor Cal
    Sounds like you need 16x8 3.5" backspacing 265/75/16 to not rub at all and have them stick out slightly...
  9. Apr 26, 2014 at 5:54 PM
    Zach faf
    Zach
    Virginia
    03 tacoma trd
    Thanks a lot
