Best size rims and tires for 2021 Tacoma SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrlewis1, Aug 22, 2024.
  1. Aug 22, 2024 at 7:48 AM
    jrlewis1
    jrlewis1 [OP] New Member
    Jacob
    I'm looking at getting new wheels for my 2021 Tacoma SR that's stock (no lift or level) but don't know which route to go.
    If anyone has any recommendations for both wheel size and lift/level options, I'd greatly appreciate them. Pictures would be awesome too.
    Thanks in advance!
  2. Aug 22, 2024 at 7:52 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    What are you trying to accomplish? Can’t really provide input without knowing what you want the change to achieve.
  3. Aug 22, 2024 at 7:56 AM
    jrlewis1
    Jacob
    Looking to get bigger wheels. Initially was interested in 18’s but was told I’d need to lift it some. Was curious if most people go that route or just stick with 17’s?
  4. Aug 22, 2024 at 8:07 AM
    BLtheP
    Plano, TX
    Wheel size won’t change fitment. Tire size changes that. You can have a tire that is the same overall height as stock but with a larger wheel inside it.
    Regardless, lift won’t be what clears larger tires. Making room in the wheel wells is what does that.
    Your stock tire size on an SR should be 245/75R16 which is a 31x9.5” tire on a 16” wheel. You can get an equivalently sized tire on a 17” wheel by choosing 245/70R17. There isn’t an equivalent for 18” in that size, if there was it would be 245/65R18.
    You can also step up to 265s which will widen the tire a bit and you can step up by an inch. So for stock height 265s, you can use 265/70R16, 265/65R17, or 265/60R18. If you want tires that are taller than stock, then 265/75R16, 265/70R17, or 265/65R18 are the options that will fit.
    If you get wide aftermarket wheels like 18x9s or something like that and something that has offset of 0 or more, chances are high that most tires you install are going to rub somewhere. Stock dimensioned wheels will always fit best because they were designed for the vehicle.
  5. Aug 22, 2024 at 8:35 AM
    jrlewis1
    Jacob
    Wow thank you for all that great information that’s really helpful. Based off what you said would a 17x8.5 rim with a 265/70R17 tire cause any rubbing? And the offset is +18
  6. Aug 22, 2024 at 7:42 PM
    BLtheP
    Plano, TX
    8.5 is a bit wide, so maybe. The offset being +18 might make it not an issue. If it was -18 it would pretty much be a guarantee to rub.
  7. Aug 23, 2024 at 2:28 PM
    Leaguer4
    Leaguer4 Well-Known Member
    What’s your definition of “best”?
