best size upgrade on a 17 inch rim?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josepenajr, Oct 3, 2013.
  1. Oct 3, 2013 at 6:12 PM
    josepenajr
    josepenajr [OP] Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    i want bigger tires i have stock 17 inch rims with the stock 2013 taco tires P265/65R17 ...thanks
  2. Oct 3, 2013 at 6:34 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    275/70/17 in a load range C. do not go with a heavier tire, mpg will suffer greatly.
  3. Oct 4, 2013 at 5:15 AM
    josepenajr
    Laredo , Texas
    thanks man!!
  4. Oct 4, 2013 at 5:31 AM
    josepenajr
    Laredo , Texas
    what about 275/75/17?
  5. Oct 4, 2013 at 5:35 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    No such thing. Are you going to lift it? If not, 265/70R17. If you are and are willing to cut 285/70R17. If lifting and not wanting to cut 275/70R17.
    Sorry, just saw you have a 3" lift. Read other threads. Search "285/70R17" and see what trimming I'm talking about.
  6. Oct 4, 2013 at 5:36 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I'm running 265/70/17 and have little rubbing on the front mudflap. No mudflap and no rubbing.
    With the 275/70/17 you would probably have to remove the mudflap to avoid rubbing so with 275/75/17 you'll maybe have to do some trimming.
  7. Oct 4, 2013 at 5:42 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
  8. Oct 5, 2013 at 11:08 AM
    josepenajr
    Laredo , Texas
    thankss i think i might look into the 275 70 17
  9. Oct 5, 2013 at 11:17 AM
    josepenajr
    Laredo , Texas
    what do u recommend? 265/70/17 or 275/70/17
  10. Oct 5, 2013 at 11:22 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    OZ-T runs 275/70's with no issues. He's on 885's (no top plates) and Dakars. IIRC
    I picked up a set of BFG 275/70 but I am waiting on wheels for them. They are heavy but cooper and hancook make them in a load range C. Those will probably be my next depending on how the BFG's are.
    Also 1stacoma runs the BFG 275/70
