Best size wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 504Tacoma, May 12, 2020.
  1. May 12, 2020 at 6:36 AM
    504Tacoma
    504Tacoma [OP] Member
    2018 Tacoma SR5
    I just lifted my 2018 SR5 with a rough country 3 inch lift. I'm still running stock wheels as of now but want to change that without any rubbing. I've read many places that 285/70/17's will fit just fine. Anyone have experience with this or can recommend another thread? If you have pictures, I'd love to see them with your wheel/tire combo information!
  2. May 12, 2020 at 6:38 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Wheels or tires? My favorite wheels are cheese wheels :oops:
    Taco_Coma likes this.
  3. May 12, 2020 at 6:38 AM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    Get ready for the :crapstorm:
    There have been many threads on this subject. Using the search function on this site or google will be your best bet :thumbsup:
    edit:
    welcom to TW BTW
    try keywords like 33’s on a 3rd gen, 285’s on a third gen, 255’s, skinny 33’s
    If using google add “site:tacomaworld.com” if you wish to keep it limited to TW
  4. May 12, 2020 at 6:40 AM
    TacoPharm
    Phil
    San Diego
    Mmmmm, cheddar :hungry:
    Skydvrr[QUOTED] and BadlandsTACO like this.
  5. May 12, 2020 at 6:46 AM
    BadlandsTACO
    BadlandsTACO Captain Quarantine
    '13 TRD Sport DCSB
    Done: TRD Pro Skid, TRD Pro Grille Insert, Husky X-Act Liners, Clazzio Seat Covers, UNI Filter Mod, 2nd Gen TRD Pro Suspension, Wheelers 1.5" AAL, 17" SCS SR8 (Gunmetal), Falken Wildpeak AT3W 265/70/17, Amber Morimoto XB LED Fogs.
    You're going to get a lot of recommendations to utilize the search function. From what I've gathered the tire size specified fitting is going to directly relate to the wheel specs and alignment you can achieve. Good luck!
  6. May 12, 2020 at 6:49 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    A 17 inch rim will have more options for tires than a 16. Not sure if that’s what you’re asking
  7. May 12, 2020 at 7:14 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    285/70/17’s on 17 by 9 -38 offset will require a saw and hammer.
  8. May 12, 2020 at 7:34 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Go Pizza Cutter!
  9. May 12, 2020 at 8:02 AM
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    17 inch wheels are the best size to go with. You'll have the most tire options. 285/70/17's are the best tire to go with in my opinion, but you'll need to do a cab mount chop, and a regear, but even stock you should do a regear so that's a bit of a moot point. So add in $2500 ish for regear to 5.29's, and probably a few hundred for a cab mount chop. This is assuming you already have a lift. All in I'm about $10k into my suspension. $5500 lift kit (I installed), $2500 for gears installed, and then miscellaneous. $2000 for wheels and tires.
  10. May 12, 2020 at 8:34 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    15 inch is ideal for offroad (larger sidewalls, less chance of bending the rim, however wont clear the calipers on 3rd gen..)
    16inch limits tire sizes that are available (tire manufacturers only make certain sizes in a 16" truck tire), most steel rims in 16's do not clear calipers due to design most I've seen for a 16" rim are 33" 255/85/16's...
    17inch while not giving a HUGE sidewall it is sufficient, and gives you an ample tire selection, and can go from stock size tires all the way up to a 40"
    18 sidewall is small on anything smaller than a 33, and not recommended to go any bigger unless you are a mall crawler, you lose sidewall height, and airing down has less effect...
  11. May 12, 2020 at 8:50 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    16” if you want to be an actual or just look like a real off roader. Everything else is for photos.
  12. May 12, 2020 at 9:20 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    They will rub, the question is, how much and are you ok with that.
    For every person with “X” configuration that say they have no rubbing, there are dozens that do. Anyone who says they don’t rub take with a grain of salt.
    stun gun likes this.
  13. May 12, 2020 at 12:54 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    265 75 16
  14. May 12, 2020 at 12:54 PM
    stun gun
    Aaronski
    Tacomas.
    /thread
    9th[QUOTED] likes this.
  15. May 12, 2020 at 12:57 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    OEM wheels are the best size and backspacing.
    16x7 and 265/75-16 to correct your odo.
    Doneskies.
