Best Sound Deadener and Insulation Sheets?
Discussion in 'Audio & Video' started by Iggy, Jun 12, 2015.
  1. Jun 12, 2015 at 2:55 PM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I'm looking to add some sounds deadening sheets that help with noise and temps. What's the best stuff out there?
    I'm planning on doing the install myself so if it's easy to cut and apply is even better.
    Thanks!
    Manfred likes this.
  2. Jun 14, 2015 at 8:53 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Manfred likes this.
  3. Jun 14, 2015 at 10:33 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
  4. Jun 14, 2015 at 10:35 PM
    Iggy
    Northern CA
    Check out the build
    Thanks! I was looking at those but had no idea. Should I add the black foam too?
  5. Jun 15, 2015 at 9:56 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    With the Shok deadener, it also acts like a dampener and you will find you most likely will not need the "black foam". Using the shok deadener i have no use for the foam pads but with the use of other deadener i have.
  6. Jun 15, 2015 at 12:45 PM
    Iggy
    Northern CA
    Check out the build
    Thanks @manethon! I appreciate the help.
  7. Jun 15, 2015 at 12:49 PM
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    A lot of folks use the stuff from here: http://www.raamaudio.com/
    I just ordered Package 1 to do the doors and rear wall of my access cab.
  8. Jun 15, 2015 at 1:12 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Np, We have a superior adhesive and butyl formulation vs market.
    Also, the thickness of our foil is about 1/4(1mm) that of the competition as we don't "buff" our deadener specs with foil thickness.Our deadener is also some of the thickest on the market.
    Shok matt V2 was designed and implemented for the needs derived from world class SQ competitors to reduce/ dissipate the rear wave behind the mids. For reference, the group buy I'm hosting is almost 50% less than what the market outside of this would pay:)
  9. Jun 15, 2015 at 1:14 PM
    Iggy
    Northern CA
    Check out the build
    @manethon I'll have to talk to you about getting some. Do these have an R-Value?
  10. Jun 15, 2015 at 1:26 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Check pm :)
  11. May 22, 2018 at 5:16 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    A fellow canuck selling deadner that I need... Hello hijack
