Best sound deadening for extreme heat
Discussion in 'Audio & Video' started by BradsTaco, May 11, 2019.
  1. May 11, 2019 at 6:41 PM
    BradsTaco
    BradsTaco [OP] Well-Known Member
    Texas/Montana/Florida
    2014 TRD 4x4 DCLB
    I’m thinking about moving to Vegas in the next year or so and I’m looking for a recommendation on sound deadening I have some nioco currently that I ordered but I trying to figure out if the extreme heat will melt the glue and allow it to run or soften enough to make the deadening peel off or slide down. Anyone have any suggestions or know if this is something i need to worry about? Thanks
  2. May 11, 2019 at 7:37 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    HushMat.... temp rating -30-500 degrees Fahrenheit.
    Only sound deadener with a vehicle fire safety rating.
    Made in the US...
    Soundskin is junk, they did a great job using 12v industry "influencers" to market the product...
    Stinger Roadkill and Dynamat are ok quality chinese sourced deadeners...
    BradsTaco[OP] and Tatts521 like this.
  3. May 12, 2019 at 3:41 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
  4. May 12, 2019 at 6:09 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    The guys on Five Star Car Stereo YouTube have had a piece on Stinger Roadkill and dynamat extreme stuck on the outside wall of their shop for several years now. It sits in the sun and rain and all the weather. They’re in Clearwater FL which doesn’t get as hot as Vegas, but still gets pretty dang hot.
    No matter what you go with, make sure the metal you’re sticking to is clean. Good ol rubbing alcohol on an old rag does the trick well. You want the cloth to have some texture to get off any dirt and grime so don’t just use a soft paper towel
    opentang and BradsTaco[OP] like this.
  5. May 13, 2019 at 7:47 AM
    BradsTaco
    2014 TRD 4x4 DCLB
