best speakers for our tacomas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomonazul, May 22, 2012.
  1. May 22, 2012 at 6:46 PM
    tacomonazul
    tacomonazul [OP] Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    hi, i'm looking on changing my stock front and rear speakers, does any one have some good references?:cool:
  2. May 22, 2012 at 6:53 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    im looking on spending from 100 - 300 for some nice speakers
  3. May 22, 2012 at 6:53 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    There are a metric fuck ton of speakers that would sound great in your truck but answer me a few questions and I'll try to help you out as best I can. What's your budget, what are you plans for the audio portion of your truck, do you want to get a new headunit?
  4. May 22, 2012 at 6:59 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    i have a good budget like 400 for spekers and some more for amplifiers and subwoofers, i already have a sony 7'' head unit that gives out 56 watts rms
  5. May 22, 2012 at 7:01 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    are infinity speakers a good option?
  6. May 22, 2012 at 7:11 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    anyone try sonicelectronix online store? Or does Crutchfield price match?
  7. May 22, 2012 at 7:16 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I like infinity but am using Pioneers now.
    You need to go to an audio shop, listen, and decide for yourself. Nobody can tell you what will sound good to you.
  8. May 22, 2012 at 7:16 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    There is a audio video section, check there.
    Also there are a couple hundred previous posts asking the same question.
    Search tab it will net you alot of answers faster.
  9. May 22, 2012 at 10:36 PM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    If you buy a decent amp and good speakers you might find you don't need a sub. I'm a fan of the Polk MM lineup--the 6x9 coaxial fits in our front doors and puts out a ton of bass if you amp it (I had a pair at 150w rms each speaker). The sound quality is definitely up there, but they are still coaxials, so you will get better sound quality out of some good components like the CDT HD-690 6x9 system. I have run Infinity and they have great clarity but lack bass and lower midrange compared to Polk. CDT has better sound quality than either Polk or Infinity imo.
  10. May 23, 2012 at 6:28 AM
    geoff7877
    geoff7877 Well-Known Member
    Petaluma, CA
    2018 TRD Off Road 4X4 Double Cab
    My stereo is the SR5 stock system. Sounds ok, but there's a huge difference from the upgraded JBL and systems that were in my last two cars. How much will upgrading the speakers ONLY improve the sound? I don't have a budget to speak of right now. My budget was absorbed just by buying the truck!
  11. May 23, 2012 at 9:19 AM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    Personally I think the stock speakers soun great. They put out decent bass and sounds good overall. If anything like a previous post stated upgrade the headunit. From previous experience just upgrading the headunit made the stock speakers sound 100 times better.
  12. May 23, 2012 at 11:03 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Not to mention just about any aftermarket head unit will have about 2x the power which will also make the stock speakers sound better. Lots of 'better sounding' aftermarket speakers are designed to run on more power which means that the low power output of the stock deck will underpower them and they could actually end up sounding worse. Either way, you'll want an aftermarket head unit for best sound (even if you add aftermarket speakers & an amp you won't want to run them off of your stock deck for best sound) so I would start there before you start with all your speakers.
  13. May 24, 2012 at 6:39 AM
    geoff7877
    Petaluma, CA
    I don't really want to mess with swapping out the factory head unit because all of the extra features that I love. I'm also NOT looking for bolt rattling bass or power. I listen to rock for the most part and want to crank it without losing so much power. How much would adding an amp to the stock head help?
  14. May 24, 2012 at 8:16 AM
    Ostrichsak
    Jer
    You can get any features you love in the stock deck and then some. By swapping out the stock deck you're not going to get bolt rattling bass because it's simply not possible with the factory speakers. Aftermarket head units generally have 50 watts x4 channels peak and around half that continuous. Factory decks such as this one usually have 1/4 those numbers which just isn't enough to get quality sound out of anything. Then, the aftermarket head unit will give you external RCA outputs if you want to add an amplifier down the road. To add an external amp to the factory unit you will need to do a high/low converter and the performance after that isn't going to be that good since you're not using a clean signal to amplify. This means that anything present in the line will be amplified, including noise. Sure you can do it, lots of people have, it's just not ideal. You can get a quality head unit for not much more than some speakers and in the end it will yield much cleaner, louder sound even with the stock speakers. In addition you can get USB inputs, AUX inputs, Bluetooth built in so you can have hands free calling & stream your music wirelessly and all sorts of features that the factory head unit doesn't give you. So, if you want better sound w/o breaking the bank or adding external items (more things to break) I still think an aftermarket head unit is the best bet. You don't have to go that route but I've done car audio & video systems for decades and based on what you've said you want I think you will be happiest changing out the factory deck for one with more & cleaner power and more features versus speakers or speakers & amps. If you like the features your deck has now you'll be amazed by what you were missing out on once you have an aftermarket head unit. Up to you.
  15. May 24, 2012 at 3:32 PM
    Hubs
    Hubs Well-Known Member
    Yes, but they like power to drive them. Sound fantastic when matched with power.
  16. May 24, 2012 at 8:00 PM
    Ostrichsak
    Jer
    By the way, you don't have to take my word for it. Click this and then this. There's LOTS of posts like that on this forum and every other car forum on the internet because factory head units suck out loud. Aftermarket head units put out not only more power but they also have better sound with cleaner power and better equalizers which make a world of difference. I mean, you're welcome to replace your stock speakers with an aftermarket speaker that's designed to run off of low power which will yield the best sound with the stock deck but it also limits yourself down the road should you go with an external amp or better deck or something. You'll pay more for a full set of speakers and the labor to install them then you will a decent head unit and your sound will be marginally better... at best. Worst case scenario you end up with speakers that require more power to function (most aftermarket speakers) so your head unit will under power them and could potentially sound even worse. There's no chance that your speakers will sound worse by upgrading your head unit. It's just not going to happen. Now if you do that and down the road you want more sound you can easily upgrade by adding in an external amp running clean RCA inputs the way amps were meant to be fed or you can even upgrade to an aftermarket speaker since now your deck power is over 2x higher than what you have now. I'm just saying...
  17. May 25, 2012 at 6:21 AM
    DevL
    DevL Well-Known Member
    WTF are you talking about? Extra features? The only extra feature you might lose is functioality of the right side steering wheel controls.
    You do not want to put a different amp to the stock speakers. Get a new head unit. Or you, who knows nothing about car audio, can ignore the people who have tons of experience and make audio decisions based off imagined misconceptions.
  18. May 25, 2012 at 6:25 AM
    DevL
    I think the stock Tacoma sound system is the very worst stock sound system I ever heard. Its ehat drove me to rip out everything down to the bare steel door panels, floor, and roof and put several grand into a stereo upgrade.
  19. May 25, 2012 at 9:11 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    wow, way to be a dick..
  20. May 25, 2012 at 9:23 AM
    Ostrichsak
    Jer
    It was pretty clear that the OP wasn't getting the sugar coated helpful approach.
