Best Stock Replacement Rear bumper 2005
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Jan 12, 2022.
  1. Jan 12, 2022 at 9:42 AM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    I would like to replace my rear bumper with a factory stock replacement to keep truck original. What are your recommendations for this and where is the best place to get one. This is the only area on the truck that is rusted and removing it and having it repainted is not an option. I would rather replace it. Thanks for any comments on this.
    paul
  2. Jan 12, 2022 at 10:04 AM
    Two_Track_
    Two_Track_ Member
    Luke
    Utah
    05 ACLB TRD
    OME 885’s with full Dakar pack 265/75/16 Duratracks Stock OR Wheels SPC UCA’s ARE MX Topper
    Facebook Marketplace, Craigslist, or anywhere online. Should be able to have one shipped to your house. If it is color matched, then you may be looking at a dealership.
  3. Jan 12, 2022 at 9:27 PM
    red8
    red8 Well-Known Member
    matt
    az
    2014 tacoma dbcb off road
    chaos fab uni-ball uca's ome w/ 886's arb deluxe bull bar prinsu roof rack pef rear bumper spidertrax 1.25 spacers ramsey 5500 winch safari land snorkel 35's with DRT relocation kit -- 2.5 in fender and flare chop 17 rrw's -- bronze miso custom map and dome lights --red/white BAMF trilogy skids BAMF rear diff diaper BAMF gas tank skid pending arb dual compressor with vair 2.5 gallon remote tank with dual beside and front bumper QD air hose access. radio/comms setup regear long travel?
    When I needed a rear bumper for my 05 I went to a local vehicle junk yard and they sourced it for me in another yard's inventory. They usually share their stock and can help you find one. Paid 50 bucks for a perfect bumper. Check your local vehicle yard out.
  4. Jan 13, 2022 at 1:37 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  5. Jan 13, 2022 at 6:26 AM
    Paulrv6
    paul
    2005 Tacoma
    Matt, unfortunately I live in the prime rust belt so a good local find is most likely not going to happen. Thanks
  6. Jan 13, 2022 at 6:30 AM
    Paulrv6
    paul
    2005 Tacoma
    The other problem I am finding is that I can't find one that is compatible with the factory hitch. They don't have the two raised caps for the bolt heads on the hitch mounting.
    Paul
  7. Jan 13, 2022 at 5:28 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    What's not compatible with the hitch? The raised caps can be purchased separately if needed (or reuse your existing ones).
  8. Jan 14, 2022 at 10:36 AM
    Paulrv6
    paul
    2005 Tacoma
    I guess I thought the factory hitch had the bolt heads going thru the bumper and the heads stuck up enough so they used the taller plastic caps and the bumper was different? Am I wrong in my understanding of this? Thank you
    paul
  9. Jan 14, 2022 at 5:44 PM
    burrito782
    08 TRD Off Road
    The only thing that is different are those caps (flush caps for trucks w/o hitch and dome caps for trucks w/hitch). The bumper shell and support beam are the same for trucks with or w/o a hitch. Those two bolts secure the bumper support beam to the hitch, but have nothing to do with the bumper shell. So for trucks w/o a hitch those two bolts are simply omitted and flush caps are used in place of the dome caps since obviously there are no protruding bolt heads needing to be accommodated.
    In case you're not familiar with how the bumper assembly goes together, maybe check out this thread as an example to help paint a clearer picture for you: https://www.tacomaworld.com/threads...nd-bumper-cover-removal.556093/#post-18135245
