Best suspension setup to pass recon in Oahu?
Discussion in 'Hawaii' started by DEDAFLO670, May 7, 2015.
  1. May 7, 2015 at 4:35 PM
    DEDAFLO670
    DEDAFLO670 [OP] Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    hi, I'll be moving to schofield by the end of the month and was wondering has anybody had success in getting the right set up on their truck. Like tires and rims and suspension that pass recon with ease.ive been holding up on purchasing a lift kit an wheels since I've been reading a lot about the recon laws I have a 2015 trd sport so if anybody has been successful pls share if you don't mind, greatly appreciated.
  2. May 7, 2015 at 4:49 PM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    I think "best suspension" is pretty subjective, but I think you just need the following:
    • alignment numbers all green (and printout is less than 30 days old)
    • you have rear mudflaps that cover the entire width of the tire and at least half of the tire height
    • tires are under your fenders (or fender extensions aka garden edging)
    not sure if the license plate height rule is still in effect. maybe someone else has some info on that.
    realistically, you can pass with spacers, coilovers, drop brackets, whatever, but the shitty thing is that when you change suspension parts and/or tire sizes, you're technically supposed to update your recon paperwork. you might not need to right away, but you won't pass safety if your paperwork and actual truck don't match up.
  3. May 8, 2015 at 12:58 AM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    if u wanna go big i know 6" plus 2" body will pass...not sure on the 12" bulletproof...all others will pass.
    rims and tires well this is what drives me nuts. anytime you change rims or tire size you need to go down n ipdate your recon. as long as the threads dont extend pass the flare your good to go
  4. May 8, 2015 at 2:03 AM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    My neighbor has a 70's bronco with a good size lift an 3" body lift. Recon said he had to cut the body lift under 2".
  5. May 14, 2015 at 11:23 PM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    You should just wait and come check out everyone's setups. That way you can see what we're running and if you like any of those then you'll know which way to go.
  6. May 15, 2015 at 3:09 PM
    bkiel311
    bkiel311 Well-Known Member
    Brian
    Bremerton, WA
    2024 Silver Tacoma DCLB TRD OffRoad 4x4
    Stock (for now)
    There are a lot of different setups that will pass. It's all dependent on what you want to do.
