Best tailgate locking solution? Right now leaning towards PL5400. Opinions please.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by peto48, Apr 5, 2014.
  1. Apr 5, 2014 at 10:35 AM
    peto48
    peto48 [OP] Well-Known Member
    Central NY
    2020 Tacoma DCSB TRD Off Road Cement 4x4
    Salex Center console organizer, glove box organizer, Husky Xact contour front and rear digital floor liners, OEM black running boards, TRD PRO Sema 4runner wheels black, Blackout badge kit, Bakflip MX4 hard folding tonneau.
    Looking to add a tailgate locking solution to my hard fold tonneau for added security. Currently looking at the pop & lock PL5400 with the codeable bolt so I only have 1 key to carry. Not looking to run wires for an automatic lock. Just want to make sure before I pull the trigger there is not a better solution out there by a different company. Pop & lock seems to be the most popular solution by far. I also saw a few posts about the PL5400 jamming on some people early on. All opinions on the topic are appreciated.
  2. Apr 5, 2014 at 12:46 PM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    im also on the fence between the 5400 and 5300
  3. Apr 5, 2014 at 12:54 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I installed the 5400 on my Tacoma a month ago. Real easy to install and having only one key was a goal of mine. Same key as the ignition works excellent. No problems so far and I open it about 10 times a day. Locks good and works well. Go for it.
  4. Apr 5, 2014 at 1:58 PM
    peto48
    Central NY
    Recommend a site and a reasonable price? Would like to receive it by the end of next week.
  5. Apr 5, 2014 at 2:01 PM
    jparf
    jparf blissfully biased
    Mechanicsburg, PA
    15 Silver Highlander Limited
    Truckalterations.com
  6. Apr 5, 2014 at 2:40 PM
    peto48
    Central NY
  7. Apr 5, 2014 at 3:08 PM
    Skeetdad
    Skeetdad Active Member
    SoCal
    Totally stock 2014
    I don't feel like this will hold up for years & years. During a bad rainstorm, it sort of locked up. Had to use hair dyer & graphite to get it functioning.
    At this time, it is the best solution.
  8. Apr 5, 2014 at 3:15 PM
    ToolFan66
    ToolFan66 Well-Known Member
    Littleton CO
    14 TRD Off Road DCSB 4x4
    I have been looking at this as well, as I will be ordering the bakflip G2..
  9. Apr 5, 2014 at 3:16 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    I have this one on my Tacoma. It works well enough, I just wish it had a more robust feel and that there was a more imaginative solution for locating the driver's side latch pull rod. I re-used the stock locating clip and shaped the rod slightly, but the 2nd gen tailgate and latch mechanism just isn't as sturdy feeling as the 1st gen.
  10. Apr 5, 2014 at 3:23 PM
    peto48
    Central NY
    Did you flip it around like I saw in a YouTube install video? In the video the rod was flipped so it was bent upwards and ran along the top of the tailgate.
    http://m.youtube.com/watch?v=s48fimgxYI8
  11. Apr 5, 2014 at 3:29 PM
    Juan Solo
    Juan Solo Well-Known Member
    Johnny
    Houston
    2014 4x4
    I have the same one on mine. It functions great but as mentioned I feel like the handle is going to break if I pull too hard, but so far so good.
  12. Apr 5, 2014 at 4:28 PM
    1of7627
    Mark
    Post Falls, ID
    Yes, I flipped it as per the instructions. But the rod follows an angled path to the latch that flipping it exacerbates. As the release lever is pulled, some of the travel is taken up as the rod tries to straighten (especially if the locating clip along the way isn't used) and the latch on that side disengages slightly after the right side which takes a more sensible route. Not a big deal really, but as an engineer I tend to fuss over such nonsense and maybe I'll take a closer look once I retire and have time for trivial pursuits.
    Not the fault of the Pop-N-Lock, but I was disappointed to find the composite tailgate lid or cover was held on by screws threaded into plastic nuts pushed into the tailgate, more than one of which was already stripped during assembly. And the metal itself seemed rather thin, making one wonder about the durability of the tailgate in general. It probably wouldn't have bothered me if I hadn't just dropped over 30 large into buying what will likely be my last truck. I'm sure the materials and engineering are within industry standards and everything will be fine.
  13. Apr 5, 2014 at 7:20 PM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
  14. Apr 5, 2014 at 8:30 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
  15. Apr 6, 2014 at 5:06 AM
    peto48
    Central NY
    Does one lithium grease stand out as better than the rest? And did you spray directly into the keyhole as well?
  16. Apr 6, 2014 at 7:27 AM
    Canuck
    Canuck Member
    Brian
    Nanaimo,B.C.
    Sat. Radio,Amp Research power steps&bedstep,Weathertech visors,Bakflip cover
    I installed the 5400 in January. It jammed( the lock cylinder ) on me the other day. Haven't been able to get it to work since.
  17. Apr 6, 2014 at 9:57 AM
    adio
    HI
    Not sure if brand is better than another brand, but I used this one from Oreillys.
    ABC41796-E39B-4179-B0B8-D5608924CBD1-588_aac84cfff733357bbdcab16930f5c91ead5486ba.jpg
    As for the key cylinder, I used all purpose powdered sylicone lubricant, same brand as above.
    Best thing to do is get in touch with Pop & Lock. Others got their seized up kit with a new one.
  18. Apr 6, 2014 at 10:11 AM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    Sub'd 4 future
  19. Apr 6, 2014 at 10:47 AM
    Two Tall
    Two Tall Well-Known Member
    Jim
    Ohio
    2018 TRD Off Road DCSB 4x4
    Retrax MXPro bed cover, Gentex Homelink mirror, TRD exhaust
  20. Apr 14, 2014 at 4:58 PM
    spencer44306
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
