Best three inch lift method hand down
Discussion in 'Suspension' started by Les Callahan, Jun 14, 2010.
Any posts with 265/75/16 on Bilestiens and TSB
Poll closed Jul 14, 2010.
  1. Trying to avoid a lift before buying tires.
    28.6%
  2. Want a visual of leveled truck with max tire application
    92.9%
  1. Jun 14, 2010 at 8:51 PM
    Les Callahan
    Les Callahan [OP] Member
    Seahorse
    Orlando
    08 PreRunner SR5
    Billi 1500 front, Rear TSB , Grillcraft grill, NOBAMA bumper sticker, Wet Okole front seat covers, reversed floor mats (flipped them over, now have durable black mats)
    After all your rsearch, which is the absolute best means to go
    about a 3 inch lift. what componenets and products are necessary.
    It seems that many have reqreted the shortcuts or means to
    elevating their tacos. I ,as many of you, cant afford to fina nce
    three attempts to lift my vehichle in a manner in which I may not he happy.
    Is there an all knowing, and all encompasing, hands down method to
    perform a three inch lift which is indisputitly the best most trouble
    free group of components and techniques to appl?
    Thanks,
    Les
  2. Jun 14, 2010 at 8:53 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    From my ovservations, since you are a prerunner, get a spindle lift.
    You'll get 4 inches of lift and be able to keep your alignment and all other aspects within spec. All while still keeping your comfy stock ride quality.
    BUT it obviously depends on your application.
    Just my .02 cents. Someone else correct me or elaborate.
  3. Jun 14, 2010 at 8:56 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Toytec ULK amd LR UCA
  4. Jun 14, 2010 at 9:00 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    It really depends upon what you plan on doing with the truck after you lift it. Will you be washing it every chance to get - or - will you be wheeling the crap out of it every chance you get.... Answer that question and you may get better results. jus' sayin'
  5. Jun 14, 2010 at 9:11 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    First off its Bilstein, 2nd 5100s only give 2.5" of lift. There are two types of lift. First expensive off road racing style like Icon, fox, King and many more. 2nd there are more street friendly lifts that can still hold their own off road. Say for example OME, Pro Comp, or toytec. If you get 3" you need new UCA cause it will not align perfectly. You will also need offset wheels with proper backspacing for larger tires, unless you want to run the risk of wheel spacers. Hope this helps
  6. Jun 14, 2010 at 9:12 PM
    HBMurphy
    Paul
    So California Coast
    None
    Eloquent! :)
  7. Jun 14, 2010 at 9:14 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    But it all depends on $$$. Kits range from 400-2,000 and up
  8. Jun 14, 2010 at 9:15 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
    The Camburg 4" spindles are amazing plus you get to run all your stock stuff and not have to buy new shocks, coils, UCAs etc...you will have to get longer brake lines if i'm not mistaken but for the money...spindles are the best way to lift the front of a Prerunner IMO. Then all you'll have to do is get some AALs (add a leafs) for the rear and you'll be set :)
  9. Jun 15, 2010 at 7:36 AM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    By a quick glance @ Camburg's site, I'm guessing spindles are only for the later year Tacomas, 05-09? or the 5 lug?
  10. Jun 15, 2010 at 2:25 PM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    for the 5 - luggers, ima get some in a quick min here
  11. Jun 15, 2010 at 2:44 PM
    MrGuitarguy
    MrGuitarguy Well-Known Member
    Houston, TX
    PreRunner Longbed SR5
    I was wondering the same thing as the TS. I was thinking about buying this ( ). Will I still need UCA's? What are offset wheels, and what do you mean by proper backspacing for larger tires? (Im new to this so pardon my ignorance.)
  12. Jun 15, 2010 at 2:52 PM
    bmckey4
    bmckey4 Member
    Cheapest and easiest in my opinion is the pro comp spacers And aal's you can get on eBay for $189 shipped. That's what I have on my truck. Rides fairly well on the street and takes a fair amount of offroad abuse
  13. Jun 15, 2010 at 4:05 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    What the hell is your poll question? It is not very clear what you are asking.
  14. Jun 15, 2010 at 4:16 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yea that is the ULK, great kit. Yes you will need UCA b/c it will not align perfectly. Toytec sells the LR UCA, which are probably the best bang for your buck. To fit 285s you will either need wheels spacers which pushes the tire out farther, or new wheels, both of which allow proper clearance for the 285s. 265s will clear in any situation, but b/c of the width of 285, the tire rubs on the UCA without offset wheels or wheel spacers. Still some trimming like mudflaps and other platic is required even with new wheels or wheel spacers. Am I making sense?
  15. Jun 15, 2010 at 4:29 PM
    WRrider450
    WRrider450 Well-Known Member
    Torranceish
    09 TRD Off-Road 4x4
    13" Wicked Flow Muffler
    hey sorry for the basic question, but what is back spacing and why is the running wheel spacers risky?
  16. Jun 15, 2010 at 5:41 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    ^^^^Somebody else help me on that one. Hard to give a good definition. I do know that stock is around 5.25-5.5 and the ideal bs is around 4.5. Check out the first few stickies in the wheel/tire section, they should help.
  17. Jun 15, 2010 at 5:42 PM
    WRrider450
    Torranceish
    09 TRD Off-Road 4x4
    hey thanks a bunch
  18. Jun 15, 2010 at 5:44 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
  19. Jun 15, 2010 at 5:51 PM
    WRrider450
    Torranceish
    09 TRD Off-Road 4x4
  20. Jun 15, 2010 at 5:55 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    I think you should be fine with Spidertrax( never heard of any issues with them) but I wouldn't exceed 1.25". From what I have heard it seems too much distance can wear out wheel bearings pretty fast. But like I said many people are using spidertrax. If you want pics search 285s on stock wheels in the 2nd gen section. There is a pretty recent thread regarding these spacers
