Best timing belt kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by little bear, Dec 22, 2014.
  1. Dec 22, 2014 at 7:22 PM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    Any idea of the best timing belt kit for a 2000 3.4l 4x4 tacoma .. Looking for all the pulleys, bearings, drive belts, water pump and gaskets and maybe even new thermostat ...
    Best price and place to get please...... Thank yall in advance
  2. Dec 22, 2014 at 9:04 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Rock auto has the oe asin timing belt kit
  3. Dec 22, 2014 at 9:28 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    If your on a budget check out the gmb kits from domestic gasket or mizumo auto on ebay. The idler and tensioners have all had premium ntn,koyo,skf bearings.
    Ive used them a bunch and havnt had any problems. Most of their kits are usually under $100
  4. Dec 22, 2014 at 10:30 PM
    TACO626
    TACO626 Well-Known Member
    Montclair, CA
    02 Tacoma 2.7
  5. Dec 23, 2014 at 12:30 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    http://pages.ebay.com/link/?nav=item.view&id=180729034728&alt=web
    This is the one I just installed. Comes with absolutely everything. All genuine parts. Pretty easy to install everything, just time consuming.. if yer wondering.. Was overwhelmed at first as I've never done anything like this before. But if I was to do it again, it'd be cake. Did not use the crank/cam seals though. That was another job in of itself. But at least I have them if/when I need to do it. The oem drive belts are very nice too. One more note, I was running hot after install, like 210. Come to find out, the jiggle valve in the thermostat needed to be facing DOWN! Not up. Runs at a steady 188.6 every day now. Very happy with it. And she purrs like the day she drove off the lot. At least it seems that way:D (I think my timing was off a hair.)
    Edit: Was easy EXCEPT for that darned crank bolt! Impact wouldn't even get it. Almost popped a hernia but I popped er loose finally;) And had to use a puller to get the crank pulley off. And of course I took out the radiator too, but that's pretty easy.
    5amStevens likes this.
  6. Dec 23, 2014 at 4:38 AM
    little bear
    Barry Hobson
    Canadian, Texas
    Can't thank yall enough for the responses .... Merry Christmas and thanks for pushing me in the right direction
  7. Feb 21, 2015 at 8:56 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    None of these kits come with a replacement crank bolt but I'm reading that the FSM says it needs to be replaced.
    So what's the truth? Does the crank bolt need to be replaced?
  8. Feb 21, 2015 at 11:36 AM
    ChrisH
    ChrisH Well-Known Member
    Orinda, CA
    '00 PreRunner
    Eh, I bought an Aisin OEM water pump for the 3rz recently & sent it back. Poor casting marks, scabs & rat tails. While the pump likely would've been just fine, I didn't really trust it.
    I ended up buying the Toyota branded Aisin water pump. A *much* cleaner piece, no casting imperfections.
    I'm actually wondering if the non branded Aisin parts fail the manufacturers visible inspection, yet are still usable pieces. So called "B" stock. Hence the ground off section where the make name (eg Toyota) is.
    YMMV
  9. Feb 21, 2015 at 3:09 PM
    NightProwler
    Harlan
    Maricopa, Az
    It probably should be considering you'll probly never have to get back in there to replace it for quite some time. I didn't simply because I completely forgot about it so I just used the old one. I imagine it's not that expensive. Haven't looked. But yeah get it anyways. Might as well.
  10. Feb 28, 2015 at 10:09 AM
    BTO
    California
    I picked one up at the stealer for $7 plus tax. Doing the job next weekend.
  11. Feb 28, 2015 at 11:49 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
  12. Jun 19, 2017 at 3:12 AM
    RedSki7
    RedSki7 CRF | TRD | PBR | 802
    Hollis
    Vermont
    06 AC V6 TRD OR 6sp | 02 RC 2.7L SR5 4x4 5sp
    Duck Tape, Zip Ties, & Spray Paint
    What kit would you recommend for 02 2.7l?
  13. Apr 15, 2021 at 3:21 PM
    Fishtank9
    Fishtank9 New Member
    Michael
    2003 4x4 w/ Standard Transmission
    Stock so far!
  14. May 3, 2021 at 6:26 AM
    N.NV
    N.NV Well-Known Member
    2000 TACO 3.4L
    At about 7:25 into video, that is a cool trick! Thanks
