Best tire cleaner for mud stained sidewalls
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTim85, May 20, 2020.
  1. May 20, 2020 at 6:08 PM
    TacoTim85
    TacoTim85 [OP] Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    What do y'all use to get your sidewalls looking black again instead of brown? After using simple green and scrubbing with a hard nylon bristle brush plus dawn the tires dry brown instead of black. I even use a small pressure washer up close to blast the sidewalls.
    Back in the day I used Westlies Bleach White. Well, nowadays they changed the formula and it does not work like it used to.
    What's your go-to for getting those tires clean?
  2. May 20, 2020 at 6:10 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
  3. May 20, 2020 at 6:12 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I buy this by the gallon and mix it 10:1 in a spray bottle.
    The $25 gallon lasts for years, and the stuff works really good with a tire brush.
    You can see the brown running off the tire as soon as you spray it on...
    3D Yellow Degreaser Wheel & Tire Cleaner
    TacoTim85[OP] likes this.
  4. May 20, 2020 at 6:28 PM
    TacoTim85
    It's more of a mud staining than tire blooming. Thanks, though.
    I will have to try this. Thanks.
    DTaco18[QUOTED] likes this.
  5. May 20, 2020 at 7:32 PM
    eurowner
    eurowner Duke Sky
    Scoty
    High pressure power sprayer should help.
  6. May 20, 2020 at 7:35 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Adams tire and rubber cleaner is unmatched. Nothing will make your tires look as good as that cleaner.
  7. May 21, 2020 at 12:17 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Would think any heavy duty degreaser would work just be cautious or aware of the rims. I’ve used purple power 4-5 applications but it wasn’t mud staining but probably blooming. I’d still be down for faster easier solutions
  8. Aug 8, 2020 at 2:22 PM
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
  9. Aug 8, 2020 at 2:24 PM
    GeorgiaAsh
    GeorgiaAsh Well-Known Member
    Acworth, Georgia
    2019 Silver SR5 DCSB
  10. Aug 8, 2020 at 2:26 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Did you find a good option?
  11. Aug 8, 2020 at 9:50 PM
    TacoTim85
    This works really well. Follow the instructions and maybe wear chemical gloves etc. Not kidding. It will irritate your skin pretty bad. I had small red splotches and a burning feeling on my skin. I used a nylon brush to scrub briefly while not allowing it to dry at all. Follow the label. :thumbsup:
  12. Aug 8, 2020 at 10:06 PM
    Superhulk LB
    Josh
    Oregon
    Thanks. I’d be searching the forum today and came across your same question. The dried mud and brown tire is not a good look.
  13. Aug 8, 2020 at 10:13 PM
    TacoTim85
    Yeah, part of the brown look can be tire blooming which is even harder to get rid of than mud... having the right products and a nylon brush will get it black again. Finish up with tire shine like @C41n
    Superhulk LB[QUOTED] likes this.
  14. Aug 8, 2020 at 11:40 PM
    Snowater
    Snowater Well-Known Member
    Pete
    GJ Colorado
    2000 Tacoma sr5 V6 5 speed ( silver queen)
    High pressure self serve car wash with wheel degreaser works for me. I can get the rest of truck clean in driveway but need the carwash for tires.
  15. Aug 9, 2020 at 7:28 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I'll 2nd this cleaner. Then once the tire is dry I use Meguiar's Endurance Tire Gel. I rub it on with a foam wax applicator pad then come back in 30 minutes and wipe the excess off with a microfiber towel. I only put 1 coat on so I don't have to shiny of a tire. My tires will look good for 6 weeks easy before I have to repeat the process.
    https://www.walmart.com/ip/Meguiar-...MIicTns6mO6wIVBL3ICh3yRwZ5EAQYASABEgJpefD_BwE
  16. Aug 9, 2020 at 8:04 AM
    Tacospike
    Two Trucks
    Same for tire gel.
    Works great, last long and doesn’t fling off on fenders. I also let it sit overnight before I drive after applying.
    CusterFan[QUOTED] likes this.
  17. Aug 9, 2020 at 8:05 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Purple Power and a stiff bristle brush.
  18. Aug 9, 2020 at 8:08 AM
    RadioTaco
    RadioTaco Well-Known Member
    SoCal
    2019 MGM TRD OR DCSB
    Chemica Guys all the way. VRP for the win. Meguiars is okay, but VRP is better imho
    C41n likes this.
