Best tire size for best mpg's and greatlooks
Discussion in 'Wheels & Tires' started by sebiotacoma, Oct 9, 2009.
  1. Oct 9, 2009 at 6:30 PM
    sebiotacoma
    sebiotacoma [OP] Well-Known Member
    Corpus Christi Tx
    TRD OFF ROAD
    wet okole seat covers,weathertech floor mats,wheel skin wheel cover,factory bed mat,factory skid plate,s.s. n-fad steps,undercoating,transmission TSB,REAR SPRING TSB,TRUCK BED DIVIDER/ROD HOLDER,paint protection film on hood-lamps-fogs-door-edge / avid off road rear bumper guard
    :confused:Does any one have information or advise on how tire sizes and tire weight affect your factory spec's and by how much. Such as mpg's and wear and tear on suspension parts. WHAT is the best mud terrain tire size for a stock 09' trd 4x4 considering weight of tire and mpg's and no lift .245/75/16 or 255/70/16 or 265/75/16. Which size tire gives me the best of both worlds. bfg's kam'2 thanks
  2. Oct 9, 2009 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Anytime you increase rotational mass (larger tires, etc..) it has an affect on performance and mpg. The BFG's are a heavy tire. The size you probably want is a 265/75/16
  3. Oct 10, 2009 at 6:46 AM
    DIRTRIDER
    DIRTRIDER Active Member
    EAST AURORA,NY
    07 WHITE SR5 4X4 V6
    BULL BAR,DRIVING LIGHTS W/ OEM SWITCH,BLACK STOCK WHEELS,265/75/16 TIRES,XM RADIO,EXTRA BED D-RINGS,SPRING TSB,5100'S @ 1.75",FOG LITE MOD, A/C COMP.MOD
    I went from the stock 245/70/16 to a pretty chunky 265/75/16 all-terrain tire and lost 2 mpg. No lift in my truck and no loss of performance and it rides good.
  4. Oct 10, 2009 at 6:54 AM
    sebiotacoma
    Corpus Christi Tx
    TRD OFF ROAD
    Thanks alot that's what I need to known
  5. Oct 10, 2009 at 7:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you adding 7.5% to the odometer when you calculate MPG?
  6. Oct 10, 2009 at 7:30 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Stay with the OEM setup.
  7. Oct 10, 2009 at 2:36 PM
    dannythefrenchie
    dannythefrenchie Member
    Danny
    gatineau,quebec,canada
    2006 tacoma 4x4 4 drs long bed
    i juste change mine today and 265/75/16 is rubing in the fender so a to take 265/70/16 and it's ok...:D
  8. Oct 10, 2009 at 2:55 PM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    huh? elaborate :)
  9. Oct 10, 2009 at 3:11 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    The 265/75s are taller than your stock tires, so your odometer will be the 7% off Chris mentioned. You probably only lost 1mpg...
    Check the tire calculator out...
  10. Oct 10, 2009 at 3:25 PM
    sebiotacoma
    Corpus Christi Tx
    TRD OFF ROAD
    Is your truck rubbing on stock height with 265/75/16.
  11. Oct 10, 2009 at 3:40 PM
    jab08
    jab08 Well-Known Member
    Alabama
    02 T4R 4wd
    Just wondering my 2000 tacoma has 265/75R15 which were I think a factory option. My door frame said it came factory with 225/75's just wondering if you got the factory optioned larger tires do they recalibrate the odometer? Or would I also need to add a percentage?:confused:
