Best to Lock diffs or not climbing side hill on ice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dbarffish, Dec 31, 2022.
  1. Dec 31, 2022 at 10:02 PM
    Dbarffish
    Dbarffish [OP] Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Do the locked diffs just make you slide out more? My neighbors driveway is total ice on an uphill and basically he is stuck up there now. Friends jeep had to chain up but it made me wonder if he was making it worse locking his diffs.
  2. Dec 31, 2022 at 10:21 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Depends. Off-camber will sometimes pull you into things while locked.
  3. Dec 31, 2022 at 10:22 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    In that situation I don't think it is going to make much difference. Sometimes chains are the only solution. But in most cases a locking diff can cause more problems than they solve on ice/snow.
    hiPSI likes this.
  4. Dec 31, 2022 at 10:39 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    If locking front and rear would mean 4 wheels spinning than don't.
  5. Dec 31, 2022 at 10:47 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Throw some coarse sand on the ice and/or chain up. Locked or unlocked.
  6. Dec 31, 2022 at 10:55 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    You get more grip but once it does slip the whole axle may slide off to the side - depending on the situation that could be quiet dangerous. On ice, I personally prefer unlocked with electric control handling traction on a per tire bases.
    Wulf and Chew like this.
  7. Jan 1, 2023 at 5:16 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    When a locked diff breaks traction it loses lateral stability because both tires are slipping. With an open diff one tire is almost guaranteed to not be slipping when you break traction so the non-slipping tire helps maintain some lateral stability. A locked diff will break traction later than an open diff, but ice offers little to no traction so we can't create something out of nothing. If the slope is steep enough and the ice is slick enough that a static tire slides there's not much of anything that can be done. Start rigging and winching.
  8. Jan 1, 2023 at 5:18 PM
    Bishop84
    Bishop84 Well-Known Member
    I've always had it cause me to dig in deeper.
    Deflate is first step. I lived on a crazy hill once and had to deflate some days.
    hiPSI likes this.
  9. Jan 1, 2023 at 5:19 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    IMO you definitely do not want a locked diff for ice/snow. I had a S10 with a lunchbox locker and that thing was dangerous in the ice and snow. Start breaking traction and the rear end just goes sideways.
    mattleg likes this.
  10. Jan 1, 2023 at 5:33 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Have a Dakota R/T with limited slip, when it was a daily I had to just tap the throttle a few times to get going in snow. Any sustained off idle torque broke traction and the rear would just slide down the road crown.
    Super fun when it was play time, not some much trying to make it to a class.
    Delta09[QUOTED] likes this.
  11. Jan 1, 2023 at 5:35 PM
    Wulf
    rock raisin
    It depends on the conditions and the spot.
    If you're on an icy slope with the rear locked it's more likely to slide the rear out to the downhill side
  12. Jan 1, 2023 at 5:40 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I never lock on snow and ice. I turn VSC off tĂło. Lower pressure in tires to 15 psi. Good luck.
