Best topper roof rack system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lightfire, Jan 3, 2010.
  1. Jan 3, 2010 at 3:24 PM
    lightfire
    lightfire [OP] Well-Known Member
    For a Century truck topper:
    I have a choice of these:
    Thule Pro Cap Rack System Thule Pro Cap Rack System
    Tracker II Rack w/o Fairing Tracker II Rack w/o Fairing
    Tracker II Rack w/Fairing Tracker II Rack w/Fairing
    Rapid Aero Rack w/ Fairing Rapid Aero Rack w/ Fairing
    Rapid Aero Rack w/o Fairing Rapid Aero Rack w/o Fairing
    Thule Rain Gutter Bracket Thule Rain Gutter Bracket
    Thule Track Only
    And a choice of these:
    47" Rapid Aero Load Bars-Comp 47" Rapid Aero Load Bars-Comp
    50" TrackerII Load Bars-Comp 50" TrackerII Load Bars-Comp
    53" Rapid Aero Load Bars-FS 53" Rapid Aero Load Bars-FS
    58" TrackerII Load Bars-FS&Com 58" TrackerII Load Bars-FS&Com
    65" TrackerII Load Bars-FS 65" TrackerII Load Bars-FS
    Rapid Aero Big Mouth - Bike Rapid Aero Big Mouth - Bike
    Rapid Aero Utility/Canoe Kit Rapid Aero Utility/Canoe Kit
    Rapid Aero Cast Away Rapid Aero Cast Away
    Rapid Aero Top Deck - Kayak Rapid Aero Top Deck - Kayak
    Rapid Aero Quest Cargo Bag Rapid Aero Quest Cargo Bag
    Rapid Aero Flat Top - Ski Rapid Aero Flat Top - Ski
    Tracker II Big Mouth - Bike Tracker II Big Mouth - Bike
    Tracker II Utility/Canoe Kit Tracker II Utility/Canoe Kit
    Tracker II Cast Away Tracker II Cast Away
    Tracker II Top Deck - Kayak Tracker II Top Deck - Kayak
    Tracker II Quest Cargo Bag Tracker II Quest Cargo Bag
    Tracker II Flat Top - Ski
    Thule Awning #326 Thule Awning #326
    Thule Conduit Box #317 Thule Conduit Box #317
    Thule Eye Bolt (2 pcs) #320 Thule Eye Bolt (2 pcs) #320
    Thule Ladder Lift System #329 Thule Ladder Lift System #329
    Thule Ladder Tilt System #339 Thule Ladder Tilt System #339
    Thule Load Stop #344 Thule Load Stop #344
    Thule Tilting Load Stop #345 Thule Tilting Load Stop #345
    I have not seen any of these systems up close. What I am looking for is basic rails that don't put much extra drag on the vehicle but where I can add bars, stops, etc to carry virtually anything I want up to weight limit. In other words I will not be purchasing any accessories right now; just want to order the best rack on the topper for expansion later on. (sorry about the bold letters - system would not let me change them once I cut & pasted)
    Thule LockingLadderHolder #349
  2. Jan 3, 2010 at 4:57 PM
    lightfire
    title edit
  3. Jan 3, 2010 at 8:17 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Compare the Tracker II and the Aero bars on Thule's website.
    Personally I like the Tracker II over the Aero bars, but the Aero's are going to be more, you guessed it aerodynamic. My opinion is that the Tracker II's are a little more heavy duty and the aero system is just designed for a more modern look which I personally don't care for.
    Here's how Thule describes them:
    Load bars attach to Thule feet and are positioned across the roof creating attachment points for Thule accessories. Bars are sold in multiple lengths.
    Use the Thule Fit Guide to find the right load bars for your vehicle.
    Rapid Aero™
    Aluminum Bar - Premium, lightweight aluminum load bars that are stylish, aerodynamic and weather resistant. Upper T-slot for simplified mounting of accessories. Attach to mounted Thule Rapid Aero base rack feet.
    Square Bar
    High-strength plastic-coated square steel load bar, attach to be mounted to standard Thule base rack feet.
    Fairing
    The Thule fairing helps air to flow over the bars for better aerodynamics and reduced wind noise when your base rack is not in use.
