Best touch up paint method
Discussion in 'Detailing' started by PackCon, Feb 21, 2016.
  1. Feb 21, 2016 at 6:02 AM
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Ok, so was detailing my Super White Taco yesterday and it was so dirty I didn't notice at some point earlier in the week someone backed into my bumper and took a section of paint off. Damages goes all the way to the metal. It's a smallish spot, less than 1".
    I'm really pissed (duh).
    What is the best paint touch up method you guys have used?
    I'm thinking of getting a touch up and clear coat pen from Toyota and hit it with some wet sanding to smooth it out. I want it as close to perfection as possible but hope to avoid spending too much for professional services.
    I'll post a picture when I get one.
    I'm hopinh because it's white it's an easier fix.
  2. Feb 21, 2016 at 2:55 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
  3. Feb 21, 2016 at 5:19 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Google "Kevin Tetz chip repair" (or scratch repair). I've used this method with excellent results. Only thing I do differently is to ditch the paint brush and use the cardboard end of a match cut at an angle as a 'brush'. Only put enough color to match and hide the metal and then fill with clear. Then finish per the video...
  4. Feb 22, 2016 at 9:36 AM
    PackCon
    Connor
    Here is a picture from this morning.
    Everything has been cleaned off. So all the markings are where paint has been removed.
    I feel like this is going to be challenging to "fix" if I'm looking for a 100% perfect job. I could get a pen and go over it or brush on paint myself but honestly it's not going to look smooth or very good I don't think.
  5. Feb 22, 2016 at 9:41 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    If it was only the small chip (to the right in the photo) you could do it yourself, but the scratches to the left will not come out good if you do it yourself. Better have it done professionally and pay the couple hundred bucks, than to fix it yourself and never like it.
    CAM37 likes this.
  6. Feb 22, 2016 at 9:43 AM
    PackCon
    Connor
    Good advice. I am going to have someone take a look at it this week and give me a quote.
    I don't want this bumper rusting on me at all in the future.
  7. Feb 22, 2016 at 9:44 AM
    CAM37
    CAM37 Well-Known Member
    2016 Black TRD Sport
    ^^ Exactly as Boer said. An area that size with touch up paint would end up looking worse than it does now.
  8. Feb 22, 2016 at 9:45 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You could buy a take off super white rear bumper off of a 2015 for $100.
    That's what I would consider instead of more expensive paint repair.
  9. Feb 22, 2016 at 9:47 AM
    PackCon
    Connor
    This is true. I'm sure someone it getting rid of theirs to put in a fab bumper.
    bahndrvr and BohlaaH like this.
  10. Feb 22, 2016 at 9:50 AM
    T4RFTMFW
    OEM bumpers are low value items for most of TW who find them useless, so it really makes a lot of sense to buy take offs.
    Front bumper covers, chrome grills, rear bumpers - you could buy all 3 for $250 and half the time the front bumper cover will include fog lights and bezels, and the rear bumper the OEM tow receiver.
    PackCon[OP] likes this.
  11. Feb 22, 2016 at 12:25 PM
    PackCon
    Connor
    What about paint matched Line-X?
  12. Feb 22, 2016 at 12:29 PM
    T4RFTMFW
    Up to you, really.
    It'd be a different texture so not sure that wouldn't bother you a little - also, that metal is super thin on those OEM rear bumpers, and easily dented or bent. Keep that in mind that the LineX may look better, and look better longer than the flimsy steel bumper it's attached to.
  13. Feb 26, 2016 at 6:31 AM
    PackCon
    Connor
    Ok guys so what should I do?
    Quote for a fix is $425. The whole bumper has to be repainted.
    1. Fix it
    2. Leave it until it rusts then deal with it - and tuck so money away in the meantime.
    3. Fab bumper
    4. Line-X in white
    5. Buy a take-off from someone else
    What I like about option 3. is it really doesn't cost that much more. Plus it will protect me more in the future. Although I don't know how much it will protect me if I'm rear ended. I would also need one that allows me to access/use my hitch which might be more expensive.
  14. Feb 27, 2016 at 3:57 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    Buy touch-up paint and experiment with fixing the scrapes on this bumper while you figure out one of the other options listed. That way you can learn what will and will not work for chips in the paint on another part of the truck and it will keep you from feeling like you are in a rush to make a decision on another option.
    For me, when I have a paint chip that needs to be fixed I usually use a toothpick for the real small crevices. If it is a little larger, put a dab of paint in the middle of the chip then use a toothpick to drag the paint to the edge of the chip. Do that a few times and you can buildup the paint to close to the height of the surrounding paint.
  15. Feb 28, 2016 at 4:56 AM
    PackCon
    Connor
    I've been looking at fab bumpers that still allow me to use my hitch. Very expensive but they really only cost 2 bumper repaints. So its really good insurance.
    This is a good idea. I'm not wanting to put up any money to fix right now. Need to think about it.
  16. Apr 27, 2016 at 12:15 PM
    PackCon
    Connor
    Update: A couple of weeks ago I got my paint pen from Amazon and started to work on fixing this damage. I cleaned the area very well and basically was going to try the method of liberally applying the paint in the scratches and knicks so that it was above the level of the factory paint. All went well, paint matches great. Then I tried to hit it with a scratch compound (McGuires Scratch X 2.0) in attempts to "buff" it all down to a smooth level.
    It didn't work so good. Compound was not strong enough to smooth and level out the paint (to be expected, I guess). I tried doing this with a 103 degree fever so I gave up quickly lol. Last week I had rotator cuff surgery. When I'm healed up I'll try to either wet sand it and polish it or try to buff it down. I'll post how it goes and I won't do it with a fever so I'll care enough to take pictures.
    Even sloppily painted it looks better than scratched up. Gotta love super white!
  17. May 16, 2016 at 4:39 PM
    bwonger
    bwonger Unknown Member
    Brian
    Santa Barbara, CA
    2016 DCSB 4x4 OR Super White
    ...does toyota use clear at all for the super white? I heard they don't.
  18. May 17, 2016 at 5:13 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Clear is mixed with the white before it is put on.
  19. May 18, 2016 at 3:34 AM
    bwonger
    Brian
    Santa Barbara, CA
    hmmm....do you happen to know if they put the paint on before or after they put chipguard on the rocker panel/under door panels? Trying to figure out the best course of action. Not sure of that's the metal there in the picture of just the primer...Couple options i've been thinking about, not sure what the best course of action is.
    1. fill in gouges with touch up paint and clear (brush style), wax
    2. remove a larger area of paint by sanding, then hit it with primer, paint, then chipguard?
  20. Jun 1, 2016 at 12:54 AM
    bwonger
    Brian
    Santa Barbara, CA
    Bump. Any suggestions?
