Best TPSM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by glenntaco12, Apr 22, 2025.
  1. Apr 22, 2025 at 10:50 AM
    glenntaco12
    glenntaco12 [OP] Member
    Glenn
    2020 Grey Tacoma SR5 2WD
    Hello guys,
    My tires are 5 years old and I think it’s time for a change, I’ve been looking at these RockTrix rims, decent looking rims and look affordable. But I’m wondering what brand of TPSM sensors that work the best for those aftermarket rims?
    Thank you!
  2. Apr 22, 2025 at 11:45 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    OEM is the best :notsure:
    Kolohe07, TS4x4 and t0p_d0g like this.
  3. Apr 22, 2025 at 12:00 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    TPMS, agree OEM is best but lots of members have good luck with generic brands.
  4. Apr 22, 2025 at 12:03 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Can’t you simply use your current sensors?
  5. Apr 22, 2025 at 12:29 PM
    InThePlains
    InThePlains Well-Known Member
    I've had OEM lasted more than 15 years, but they are too expensive to buy new.
    I use generic sensors, and Discount Tire to mount my tires. They have replaced couple of dead sensors over the years no charge for me. They just swapped one out of my wife's ES350 this weekend while rotating the tires.
  6. Apr 22, 2025 at 1:19 PM
    jasonvt
    jasonvt Well-Known Member
    Vermont
    2021 Tacoma DCSB TRD Off Road Manual
  7. Apr 23, 2025 at 4:49 AM
    MildWild
    MildWild Active Member
    Massachusetts
    TRD OR
    OEM is the only way to go as others have stated. Save yourself a few $$$ and get the Denso's off of Rock Auto. They supply Toyota with the OEM sensors and they are identical. Anything a tire shop will sell you wont last nearly as long.
    shakerhood and TS4x4 like this.
  8. Apr 23, 2025 at 5:20 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    When it's time to replace your tires buy a set from Amazon. About $40-$60 for a set of 4. Take them to the tire store and they will install them at no charge when buying tires. If you have them installed and not also buying tires they charge about $10-$15 each to install them. Which doubles the cost of buying them. I have 3 sets of Amazon sensors on vehicles. Never had an issue and the oldest set has been in for over 5 years now.
    I've seen sensors die at 7 years and I've seen them last 14. Somewhere around 7-10 is typical. At 5 years, on factory sensors, you're probably good for at least 3-4 more years.
    I've started replacing my sensors with every other set of tires. That works out to about every 7 years. I MIGHT get them to last through another set of tires but would be pushing it to get 10 years out of a set. And since it's 1/2 the cost to install them with new tires I figure it's cheaper in the long run.
  9. Apr 24, 2025 at 7:28 AM
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    I love the Autel dual band with the rubber stems. Really good sensors. I’ve seen the metal stems break off road so I steer clear of those.
  10. Apr 25, 2025 at 4:15 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Just to clarify the "rubber" Autel stems are metal too, just somewhat cushioned by the rubber where they enter the tire. Agree that they should be more resilient to trail damage, just not immune.
    JDSmith[QUOTED] likes this.
  11. Apr 26, 2025 at 5:28 AM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Yes, definitely more resilient. The metal stems also tend to corrode quite a bit with all the salt up here.
    Toycoma2021[QUOTED] likes this.
