Best transmission oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PhaderzTaco92, Apr 15, 2021.
  1. Apr 17, 2021 at 1:39 AM
    PhaderzTaco92
    PhaderzTaco92 [OP] Member
    PhaderzTaco
    2017 Tacoma trd off-road
    So what do you think I should use for my 2017 Tacoma or auto tranny?
  2. Apr 17, 2021 at 3:07 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    PhaderzTaco92[OP] and RustyGreen like this.
  3. Apr 17, 2021 at 4:44 AM
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    This!
  4. Apr 17, 2021 at 5:49 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The modern automatic transmission is about the most expensive and fussy part of the vehicle to repair -- use the Genuine Toyota fluid.
  5. Apr 17, 2021 at 9:27 AM
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    If the transmission requires GL-4, I HIGHLY recommend Ford Unicorn tears or Redline MTL. Both are extensively used in the Miata community where notchy shifts are often solved by using these fluids. Most Ford dealers keep the Unicorn Tears in stock. Makes a huge difference depending on whatever stuff the factory uses.
    https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
    https://www.amazon.com/Genuine-Ford-XT-M5-QS-Synthetic-Transmission/dp/B000NUES82?th=1
    GL-5 contains over twice as many additives as GL-4, mainly sulfur and phosphorus products. This is good in high-pressure applications (differentials), but sulfur and phosphorus react with bronze and copper. Your synchros just so happen to be made out of either copper or brass. GL-5 does not supersede GL-4, the GL rating is how much pressure can be sustained without any metal-to-metal contact between components.
    Here's a great article on GL-4 vs GL-5, including pictures of a worn-out Toyota synchronizer.
    https://www.widman.biz/uploads/Transaxle_oil.pdf
    Automatics don't care as much what you put into them.
  6. Apr 17, 2021 at 1:12 PM
    PhaderzTaco92
    PhaderzTaco
  7. Apr 17, 2021 at 3:03 PM
    Hairless_Ape
    South Jersey
    2021 F150
    You can buy it any Toyota dealership.
  8. Apr 18, 2021 at 8:18 PM
    PhaderzTaco92
    PhaderzTaco
    Thanks
