Best tune for torque converter shutter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by red5033, Aug 2, 2021.
  1. Aug 3, 2021 at 7:11 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    With every automatic I’ve owned I have tapped the throttle to trigger a downshift before trying to accelerate or go up an incline. If you simply apply a tiny bit of throttle slowly, autos tend to stay in the same very high gear and bog down. The one thing an auto cannot do is anticipate your next move.
    Junkhead likes this.
  2. Aug 3, 2021 at 7:33 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Same here. It often feels and sounds like driving over very aggressive highway ‘rumble strips.’
    BWorned likes this.
  3. Aug 3, 2021 at 10:49 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I do the same to save on the brakes when going down a long grade. I have zero issues with my automatic when going up hill. I don't even need to push the accelerator pedal down further, but keep it steady, and the transmission will downshift automatically when it senses it. You can then press the petal harder if you want to go faster just like any other automatic vehicle i've had. I would think a sensor in the transmission is faulty if you have push the pedal down to make the transmission downshift when climbing a hill...imo, its not suppose to work like that.
  4. Aug 3, 2021 at 10:55 AM
    zoo truck
    None
    Wow, thats quite a bit different then anything i've seen. Never experienced it it any toyota automatics i've had, or been in. Sounds more like a bad transmission.
  5. Aug 3, 2021 at 11:00 AM
    trouble_shooting
    trouble_shooting Active Member
    Trig
    2021 TRD Off-Road
    I have experienced this as well on my 2021 Taco. I previously had a 2020 Ram 2500 Hemi.
    When it went into MDS at low rpm if felt quite similar. My resolution was disable MDS. My resolution on the Taco is to add enough gas pedal to have it drop a gear to keep the rpm up. I am under the impression that at the lower rpm the 3.5 is in it’s akinson mode and when put under a load it feels like the MDS did under load.
    my .02 :)
  6. Aug 3, 2021 at 2:21 PM
    gudujarlson
    Minnesota
    I didn’t have any issues with the AT in my 2016 either, but being an auto I found that it didn’t always downshift as fast as I wanted so I frequently coaxed it with a quick throttle tap.
  7. Aug 3, 2021 at 5:44 PM
    zoo truck
    None
    I never have to tap the throttle going up a grade, only to save on the brakes going down....been that way from day one.
  8. Aug 3, 2021 at 5:50 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Fwiw, this is near identical to issues with the FJ transmission that ultimately ended up being a TSB transmission replacement (or perhaps repair). Right rpm and right load(light) and I could get it to shake really bad. One of the senior techs I took for a ride said ‘head back, I know exactly what this is’. He thought it was really loose lug nuts and the tire wobbling badly.
    If I took the FJ out of drive, it went away immediately and was not reproducible. I could force it in nearly any gear. I downloaded an app for vibration analysis and it had a pretty sharp peak that was consistent across the various gears.
    In the end, my subconscious just learned to give it a little more gas (or less) around the prone zone and I lived with it from ~60k miles to 190k miles.
    It was definitely a torque converter issue. I think it had something to do with tolerances and locking/unlocking.
    zoo truck likes this.
  9. Aug 3, 2021 at 5:52 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Put your foot into it. Maybe I drive like a maniac. I have not experienced any trans issue on my 2021. I don’t lightly apply the gas. I push the pedal, not to spin the wheels, but I push it.
    I wonder if some folks just lightly push into the pedal and that brings on the shudder. Get into it folks. It needs gas to get the converter spinning. Don’t try to gently accelerate, give it the gas and then let off, do it in reverse of what you are use to. Maybe that will work for you. Slam it down and slowly let off as you start to move. I think everyone’s issue will go away.
  10. Aug 3, 2021 at 5:54 PM
    RushT
    North Texas
    It wasn’t just acceleration for me. It could be steady state speed with a light load.
    Mastiffsrule[QUOTED] likes this.
  11. Aug 4, 2021 at 5:32 AM
    zoo truck
    None
    Makes sense. I still contend it was a torque converter issue when my 2020 auto sr5 was very new and had a slight shudder when coming to stop. When i slipped the transmission stick in neutral and applied the brakes it was no longer present....reason for figuring the converter. Once the truck accumulated over 1k miles it was no longer there, and hasn't returned. I just chalked it up to these parts breaking in.
    Its a different story with a buddies 2019, he still has that lugging issue which i do suspect its in the transmission from not receiving enough torque from the engine.
    JJ Diablo likes this.
  12. Aug 4, 2021 at 6:31 PM
    RushT
    North Texas
    Sorry, I should have been more clear. It was definitely related to the TC, albeit wrapped up in the transmission package.
    zoo truck[QUOTED] likes this.
  13. Aug 4, 2021 at 10:01 PM
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    Try putting the tuned truck in S6 (it will auto up and down shift for you)... See how it feels.
  14. Aug 5, 2021 at 5:05 AM
    zoo truck
    None
    On my truck there is no S6, only goes up to S5. I have to go back to the D mode for 6th gear. Been that way since new.
    cryptolyme likes this.
  15. Aug 5, 2021 at 5:13 AM
    #35
    trdquoc
    "Q"
    Like you visually can’t see S6 on the instrument cluster?
    That’s maybe something the dealer needs to look into.
  16. Aug 5, 2021 at 5:22 AM
    #36
    zoo truck
    None
    No S6 display, only up to S5. Idk, truck runs really well. I'm one of those guys that let a sleeping dog lie. Besides why would toyota want you to use S6 anyways?....makes no sense. I've always figured its done this way on purpose.
  17. Aug 16, 2021 at 5:47 PM
    #37
    Derbo2
    Derbo2 New Member
    Derik
    2020 White Tacoma TRD Sport LB
    My 2020 TRD Sport has the exact same shutter at 45-55 mph in Drive. It feels like its locking and unlocking repeatedly, creating the slipping sensation…. Approaching a small grade while cruising through traffic makes me cringe. The dealer says all is normal.
    I’d love to find a fix. Checked the transmission fluid the 2nd day I owned it.
  18. Aug 16, 2021 at 5:55 PM
    #38
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    I just got my truck KDMAX 6.0 tuned this last Sunday. I am not feeling that shutter or miss feeling I was before. Even my wife noticed that it was gone. Only have 80 miles on the tune but seems to have addressed the issue for me.
    trdquoc, PapaRee and Derbo2 like this.
  19. Aug 16, 2021 at 8:26 PM
    #39
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    S6 is auto. no point in using s-6 as that would be the same as D
    zoo truck and Sharpish like this.
  20. Aug 16, 2021 at 8:37 PM
    #40
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Not quite. S-mode has completely different shift, throttle, and torque converter lock/unlock settings from Drive, different axis systems, different curves, etc... It’s actually significantly different when you look at them in vFTuner.
