Best U-Joints for Prerunner 2 Piece Driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jan 12, 2022.
  1. Jan 12, 2022 at 12:10 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Thinking of changing u joints to eliminate clicking sound under truck.
    Had Spicer in mind to replace the old Moog ones.
    Anyone else have any good recommendations for u joints brand?
    Valuecraft or other brands any good?
  2. Jan 12, 2022 at 1:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    spicer greaseable ones.
    /thread
    Key-Rei and PzTank like this.
  3. Jan 12, 2022 at 11:27 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    this. Unless you’re lazy and won’t grease them then get the spicer SPL series.
    PzTank likes this.
  4. Jan 12, 2022 at 11:33 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    6 gearT444E likes this.
  5. Jan 12, 2022 at 11:44 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  6. Jan 12, 2022 at 11:52 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    it’s my thoughts the non greasable one is stronger, so if you’re going to be wheeling it may provide some extra performance in that regard. Not sure what the other benefits might be over greasable ones though.
    PzTank[QUOTED] likes this.
  7. Jan 12, 2022 at 11:58 PM
    PzTank
    Above the Notches
    :hattip:.
    I got lazy. Should’ve just used the googles…
    https://4xshaft.com/blogs/faq/greaseable-vs-non-greaseable-joints-which-is-better
    Strength and better sealed according to these folks.
    6 gearT444E[QUOTED] likes this.
  8. Jan 13, 2022 at 12:01 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Spicer is the OEM for Toyota for what it's worth.
    PzTank likes this.
  9. Jan 13, 2022 at 2:13 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Just did mine a week ago so go with Dana Spicer since they are the OEM for the entire drive shaft. Also even if you order your u-joint or center bearing after market they just send you the exact identical piece that you would get from Toyota just without the Toyota price and you can easily get them in rockauto. Word of warning get some extra retainer clips since the u-joint clips that come with ujoints will be a tight fit and will end up with them bulging out.
    I got these from Amazon which are thinner than the clips that come with the ujoints which solved the bulging clips and kept the u-joint from being too tight.
  10. Jan 13, 2022 at 7:26 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Get the non greaseable spicers. Should have white seals vs the greaseable blue sealed units.
    The reasoning is that the non greaseable has a triple seal on the caps and they are very much stronger.
    I've replaced all of my ujoints 4 times. The greaseable spicers are more susceptible to water intrusion and I used to break them every 4-6 months.
    I've since installed the non greaseable version the last go around and they've lasted almost 2 years.
  11. Jan 13, 2022 at 7:48 AM
    Alealexi
    Houston, TX
    Quite true. The non greaseable ujoints are there if you just want to set it and forget it. They will last a long time and if you want you can put some more Lucas red grease in them if you want the grease to last a bit longer.
    On the other hand if you are the type of person who likes to do a lot of maintenance on your truck then you can just get the greaseable ujoints and grease them every six months. They can outlast the non greaseables as long as you can grease them periodically.
    will.i.was[QUOTED] likes this.
  12. Jan 13, 2022 at 9:09 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I prefer them because I’m not likely to service them. (I have non-greaseable ball joints for the same reason.). I don’t know if they are stronger. I would think, in order to reduce production costs, they would use the same ujoint body. I have noticed the non-greaseable ujoints are drilled at the ends - that’s where extra grease is stored. Somebody needs to cut some ujoints open to compare them.
