Best UCAs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The_Gray_Taco, Aug 22, 2021.
  1. Aug 22, 2021 at 7:59 PM
    The_Gray_Taco
    The_Gray_Taco [OP] Member
    Rafael Avila
    2019 Tacoma TRD 4x4 Cement Gray
    Bilstein 8112 (front shocks) Bilstein 5160 (rear shocks) Icon RXT Leaf Pack Prinsu Roof Rack Body Armor Front Bumper CBI Skid Plate (Front & Lower Control Arms) Cali Raised LED Pods & Light Bars
    I'm looking in getting some Upper Control Arms. What do you all recommend? I would like to know which are the best overall, and what are the best for the value?
    Current set up are Bilstein 8112 in the front and 5160 in the rear.
  2. Aug 22, 2021 at 8:05 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    The_Gray_Taco[OP] likes this.
  3. Aug 22, 2021 at 8:12 PM
    The_Gray_Taco
    Rafael Avila
  4. Aug 22, 2021 at 8:15 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I just installed 8100 fronts with SPC UCA and the install went smoothly. And matched with 8112 rears with Deaver Stage 2 leaf pack.
  5. Aug 22, 2021 at 8:16 PM
    meats
    meats superwhite MT taco meats
    Justin
    Grapevine, TX & Cushing, OK
    '20 Super White DCSB 6spd MT 4x4
    Lots--
    I have JBAs-- love them but need to be able to move tire a bit more. Can't adjust them so I am swapping them out Wednesday for new SPCs. Should help get my 35's off the firewall completely. And I've already beat it back far with a 10lb sledge and done cab mount relocate. Plus the alignment shops will thank you for having SPCs. Make's their life easier when aligning our tacos.
  6. Aug 22, 2021 at 8:50 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Depends on what you’re looking to do with your truck.
    Again, your best bet is to perform independent research. There are some good articles written on the pros and cons of different manufacturers and different joints types, construction, etc.
    Most people are going to give you a very limited perspective based on what they bought. Are you looking to get make room for larger tires, add bling, or do you have another goal in mind?
    Key-Rei and Skydvrr like this.
  7. Aug 22, 2021 at 8:54 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    maybe, lots of shops don’t want to fiddle with them.
    meats[QUOTED] and Skydvrr like this.
  8. Aug 22, 2021 at 8:54 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    This, what's your criteria? Longevity? Ball joint replacement? Looks? Etc.
    71tattooguy likes this.
  9. Aug 22, 2021 at 8:54 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  10. Aug 22, 2021 at 8:59 PM
    meats
    Justin
    Lots--
    All the shops in Texas I go to work on 4x4 Toyota’s. And they all love when you have them. Shoutout To Oscar at Tread Depot in Mansfield,TX. Solid off road shop with top of the line alignment gear. They can do it all!
    Also if they don’t want to mess with an SPC I’d question the work they are doing unless it simply tires.
    AmateurTaco1313 likes this.
  11. Aug 22, 2021 at 9:00 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    How many shops have u been to?
    Grindstone likes this.
  12. Aug 22, 2021 at 9:03 PM
    meats
    Justin
    Lots--
    Not many I do everything myself. Just need alignment
  13. Aug 22, 2021 at 9:04 PM
    Stocklocker
    17TRDORDCSBAT
    The alignment shop I deal with pretty much insists on SPC’s if you want them to align a lifted truck. They are super-anal about alignment numbers and basically will send you packing unless they feel you will be leaving in a properly aligned vehicle.
    meats likes this.
  14. Aug 22, 2021 at 9:04 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Right on. That's the way to do it.
    meats[QUOTED] likes this.
  15. Aug 22, 2021 at 9:05 PM
    meats
    Justin
    Lots--
    How hot is Gilbert now? I used to live at Gilbert and chandler Rd. I miss it but not in August.
  16. Aug 22, 2021 at 9:06 PM
    meats
    Justin
    Lots--
    Yup they hate to send you away not properly aligned. Helps with the lift
  17. Aug 22, 2021 at 9:07 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Idk, I spent a lot of time in the pool today and I felt cold lol. Probably only 100. This year has been great!
  18. Aug 22, 2021 at 9:34 PM
    The_Gray_Taco
    Rafael Avila
    I’m looking for functionality and a little more clearance.
  19. Aug 22, 2021 at 9:36 PM
    The_Gray_Taco
    Rafael Avila
    My front tires were rubbing, which made me look into different solutions. A lot of people brought up UCAs.
    Skydvrr[QUOTED] likes this.
  20. Aug 22, 2021 at 9:45 PM
    Alfamoua
    Alfamoua Well-Known Member
    17tacoOR
    What adjustments are you looking for? Don't JBA has High Caster built in already? Just ordered a set of JBA to run with 35
