Best upgrades for 3rz
Discussion in 'Performance and Tuning' started by AdamB188, May 27, 2020.
  1. May 27, 2020 at 3:01 PM
    AdamB188
    AdamB188 [OP] Member
    Adam
    2003 Tacoma 4x4 2.7
    Today was a sad day for my Taco after cylinder 2 tested 43 psi, however, now I get to rebuild it!
    This will be my first rebuild and I am looking to upgrade some of the internals while I have it apart. Are there any stroker kits or other modifications that you guys recommend doing for getting some more power out of it?
  2. May 27, 2020 at 3:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. May 27, 2020 at 4:13 PM
    AdamB188
    Adam
    2003 Tacoma 4x4 2.7
    I have checked them out. I was wondering if I would see any significant gains with their stage 1 cam or if I should get stage 2.
  4. May 27, 2020 at 7:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If they don't have any dyno's, definitely give them a call.
  5. May 30, 2020 at 5:58 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Boost it. SC is easier to bolt on, turbo is more complex, both need fuel/timing upgrades.
  6. Jun 21, 2020 at 5:44 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    What’d you end up doing op?
