"Best" vendor for Bilsteins 5100?
Discussion in 'Suspension' started by hetkind, Aug 13, 2014.
  1. Aug 18, 2014 at 8:25 PM
    EastTx
    EastTx Well-Known Member
    Texas
    2017 Super White DCSB TRD OffRoad 4x4
    Actually it was just for the 4 shocks. I did the install myself. Its hard for me to spend the $$ on labor that I believe I can do myself. I am not sure if I got lucky or what.
  2. Aug 24, 2014 at 4:37 AM
    hetkind
    hetkind [OP] Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The struts came in Thursday, I got home Friday and we installed them on Saturday...We found it easiest to split the spindle at the top balljoint, and totally unhook the sway bar. Installation was about 3 hours with the second side going faster. We also had to drop the front pan to get easy access to the sway bar bolts...now for a good roadtest.
    Howard
  3. Aug 26, 2014 at 12:47 PM
    hetkind
    Howard
    Johnson City
    This should be my final post on this thread...the truck has been driven to town, to the office and to the alignment shop, to adjust the toe positive about 0.15 a side, at a cost of $65, to include a tire rotation and balance.
    Now, how do the Bilsteins ride compared to the worn out original shocks? They seem a tad overdampened, so I am noticing bumps I used to float over, on the other hand, it handles better on twisty, two lane, mountain roads. As for dirt and gravel, it keeps the corners well planted over large whoops.
    The guys at the tire/alignment shop commented on the cost of the bilsteins, I suspect they have trouble upselling them over the name brand of Monroe or Gabriel. (note: have you seen a Gabriel shock lately?)...
    Which brings a new question...are the bilsteins on the Wrangler Sahara worn out after 75k miles on the clock?
    Howard
