Best Wax - Opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by APG85, Nov 12, 2024.
  1. Nov 13, 2024 at 3:30 AM
    APG85
    APG85 [OP] Well-Known Member
    2016 Blue Pearl Tacoma TRD
    Leather Seats
    Thank you for all of the suggestions! Lots to choose from. I know little to nothing about ceramic coatings and how to do it after waxing my truck since it was new (2016). Might be time for me to dig into it.
  2. Nov 13, 2024 at 3:46 AM
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    Once you go ceramic you will never use wax again.
    ace96 and CTSpruceMica like this.
  3. Nov 13, 2024 at 4:01 AM
    bumhunter
    bumhunter Well-Known Member
    2015 Black tacoma four door long bed 4x4
    Nu finish. It’s a polish not a wax.
  4. Nov 13, 2024 at 11:35 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I'm also a Collinite fan - I use No. 885 - The fleetwax. It works great in a salt water environment (Sailboat), so I tried on my car. I won't use anything else!
    It is not for weenies... ( :p ) - It does take a wax effort to apply... you don't just squirt it on. But it works - and it lasts!
    Available on AMZ...
    The Taco is the biggest vehicle I've owned. I take a while to wash properly and wax... - When I wash my old mini, I run out of car to wash in like 10 minutes with only a cup of water!
    timw1[QUOTED] likes this.
  5. Nov 13, 2024 at 3:25 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    until recently chemical guys was my go to for almost everything but their business practices and declining quality have pushed me away.
    I use a porter cable w/ hex pads.
    basic maint. polish is the CG P40 and i think its called p4 now, its a mild polish and hard to screw up w/ it. I use it on a slightly more aggressive pad rather than using too harsh of a polish then switch to a finer pad to finish it out, this is for daily drivers for show finish thats a completely different story for a different day...
    follow that with a rewash and then i'll hit it with mothers paste wax. i'll do quick touch ups to the wax randomly w/ some butter wet CG's liquid and then their sealant.
    I generally try to stay away from any spray on gimmicks but I do like the lucas oil speed spray after washing dark vehicles but thats just a bandaid for rushing the wash.
    I'm likely going to do the carpro's ceramic on my tacoma over the holiday break.
  6. Nov 13, 2024 at 6:57 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    For everyone using polishes... BE VERY CAREFUL, These new modern waterborne finishes are very very thin, and you can damage the clear coat to beyond repairable. Even using softer pads, and low abrasive polishes, will over time deplete the clear coat. If you do this multiple times over a few years, you could/will have finish issues. Food for thought. Ski
  7. Nov 13, 2024 at 7:32 PM
    OZ TRD
    Central Coast CA
    I agree... Polishing is a poor substitute for a good cleaning and just not a good maintenance ritual for a vehicle's finish.
    - If you pay someone to clean your car - have them clean it - not polish it!
    I would never polish UNLESS damage has occurred to the top layer of paint and there was a need to get below this to try and salvage.
  8. Nov 13, 2024 at 8:32 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Way Way back in the day we used to use Johnson's Floor paste wax
  9. Nov 14, 2024 at 2:10 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Back in 1978 when I had a van I used turtle wax. Old habits die hard.
    OG turtle wax It is.
  10. Nov 14, 2024 at 2:25 AM
    BillyE
    BillyE Well-Known Member
    I’ve been liking Adam’s H2O Guard and Gloss lately. Good stuff, easy spray on while towel drying
    Gus likes this.
  11. Nov 14, 2024 at 4:20 AM
    SilverTRD Sport
    Houston, TX
    When polishing I only use Meguiar's #7 polish it has zero abrasives and does a great job in shine. You must go over it with some sort of wax or coating. Before I do any polishing I always clay bar. The key to make your vehicle shine is the prep and of course is the hardest part.
    02Duck likes this.
  12. Nov 14, 2024 at 8:40 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    Compounding and polishing to correct defects in the paint are a part of the prep process if you are concerned with protecting and preserving the vehicles finish. Even with modern paints that are thin, soft, and fragile, it takes a serious amount of inattention or stupidity to ruin clear coat by polishing "too much" regardless of if you are using a DA, large throw DA, Forced Rotation DA, or a rotary. Most of the "Polishes" being mentioned in this thread are either a sealant with chemical cleaners (Nu-Finish) or Glazes (Megs No 7) that hide imperfections by use of fillers.
    I advise against Ceramic coating daily drivers for a couple reasons:
    • maintenance of a coating requires specialized, (Expensive), products for shampoo, and touch up sprays. This is less of an issue if you have nothing already and are starting from scratch.
    • Cost and downtime for coating: coatings require a nearly perfect paint surface, so in addition to a normal prep process for a good wax or sealant, this means a 2 step paint correction, then the coating needs to be applied in a clean, well lit, climate controlled environment, to apply and let the coating cure, (coatings take multiple days to fully cure) Using CquartzPro UK 3.0 as an example: $180 for the coating, $50 for reload, $100-$150 in MF towels and applicators which will be discarded after use), $50 for eraser, $80/Gallon for a shampoo like Reset you are looking at spending somewhere around $400-$500 for the coating and a new shampoo, this assumes you have a polisher, pads, compounds, polish, and the skills to do the prep work. Otherwise you are looking at at least 1,000 to 1,500 to pay a reputable detailer to coat your vehicle.
    • If you need to repair a scratch or have any swirling you want to clean up, the process requires re-application of the coating
    • the longest you will get out of the most expensive professional coatings on the market is maybe 3-5 years with maintenance...no coating is lasting 8-10 years
    Comparing that to Klasse HGSG (my favorite sealant I have ever used):
    • Prep can be as simple as wash and clay or as involved as a full paint correction, you decide
    • $25-30 for a 1 liter container that will likely outlast the vehicle you buy it for
    • Can be applied as a wipe on, wipe off product, (seriously ignore the instructions on the bottle, letting it haze for 45 minutes makes it a pain to remove)
    • Only needs 8 hours without rain or snow to cure and a second coat can be applied which has consistently given 12-16 months of protection including winter in upstate NY
    • Maintenance washes are business as usual with whatever products you want to use, (shampoo, wash&wax, quick detailers, spray waxes, etc...)
    • Your towels, applicators, etc... just need to be washed and can be re-used
  13. Nov 14, 2024 at 9:06 AM
    SilverTRD Sport
    Houston, TX
    There are many great products out there and you will get many expert opinions. There is no perfect product, just pick your poison. However, just prep the paint that is where you get your shine, then protect it.
    Here is my prep.
    Touch up any scratches and chips. I use Dr. Colorchip due to no blobs.
    Wash with Dawn and never use it again. Dawn removes wax.
    Clay vehicle
    Polish with a buffer, I have the Porter Cable. This is a very important step because this will bring out the shine.
    Spray and wipe vehicle with 15% rubbing alcohol and distilled water. This removes all residue.
    Then apply your wax/coating which is the easy part.
    Don't rush, take your time and expect taking a full day on this give or take. Do this in the shade and don't forget lots of beer.
    APG85[OP] likes this.
  14. Nov 14, 2024 at 4:05 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    waxes are fairly outdated. There are products far better than waxing.
    Ceramic coatings are better in all aspects than a wax. They are harder, more protective and longer lasting. I used to use gtechniq products but moved on to gyeon. Pure is the product I love. last 2 -3 years. A little more work than a wax but worth it.
    If you don't like the additional work, griots 3 in 1 ceramic spray. It's a spray on and wipe off product.
  15. Nov 15, 2024 at 2:18 PM
    #35
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    First time: Dawn wash, Porter Cable if it might need it, Zaino Z-2 with accelerator. If I'm feeling strong that day, wipe off and re-apply. Then finish up with Z-8
    Subsequent: wash with Zaino, blow dry, then wipe down with Z-8.
  16. Nov 15, 2024 at 8:30 PM
    #36
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    That’s a bit of over exaggeration. It’s not something that’s going to happen instantaneously.
  17. Nov 16, 2024 at 5:28 AM
    #37
    Stone56
    Stone56 Well-Known Member
    Jeff
    2018 TRD Sport
    This is the best overall wax product I have ever used. It is cable insulator wax and it does a great job on the finish but even better, you can wax anything! You can wax your dash, your headlights, your interior, even your tires .....the key is, it does not leave white residue!
    https://www.amazon.com/845-Sealant-...8&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY
  18. Nov 16, 2024 at 6:07 AM
    #38
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Timely comment, was just wondering about this stuff! Do you need to be careful around non-painted areas or can you just go to town on the whole thing like you seem to be able to with 845?
  19. Nov 16, 2024 at 6:16 AM
    #39
    Stone56
    Jeff
    2018 TRD Sport
    This is the 845. I have used it matt finish and even super rough finish and never had a an issue.
    moon22[QUOTED] likes this.
  20. Nov 16, 2024 at 6:16 AM
    #40
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    The griots products are very good. Not magic, not exceptional, but still very nice. I like the results I got with the 3 in 1 and all in 1
    I like the color and gloss. Seems to enhance color especially on metal flake finishes. Smells nice too.
    https://www.autozone.com/wash-clean...arage-ceramic-all-in-one-wax-16oz/1172270_0_0
    For a second coat the next day:
    https://www.autozone.com/wash-clean...rage-ceramic-3-in-1-wax-spray-22oz/733625_0_0
    As a topper after a maintenance wash the 3-1 works well, as does Turtle Wax Seal and Shine. Every few hand washings, I'll use a topper. I was about once every 2 weeks.
    I do a yearly strip wash, iron remover, clay bar towel, then light polish with a DA and some griots complete compound, panel wipe, then apply a sealant. Takes about 3 hours start to finish net of cleanup.
