Best Wax - Opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by APG85, Nov 12, 2024.
  1. Nov 16, 2024 at 6:33 AM
    #41
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Came in to say the same.
    Ceramic coat it - even a DIY coating with regular washes and some spray ceramic coating to touch up will do wonders.
    https://www.amazon.com/Autokcan-Ceramic-Anti-Scratch-Hydrophobic-Protection/dp/B08MTBHS7N
    I'm using AutoKcan. Is it some cheapo-chinesium from Amazon? Yep - you betcha! Is it doing better than wax? Absolutely. With a litttle maintenance like Mothers CMX after a wash it will last a good 2 or 3 years out here in the AZ sun.
    Truck is outside 24/7 and off road once a month at a minimum. It goes in the snow up north and out in the sand in the Valley of the Sun.
    I do an Iron Decontamination with a little very light light polish in it.
    Wash it real good (2x) to get that polish and iron decontaminate spray off of it.
    Ceramic Coat it.
    It is a process. Takes a good half a Saturday. But that's 4 to 6 hours every 900 to 1000 days.
    I have people ask me - Why not Ceramic coat it and THEN wax it for belt and suspenders protection? And you absolutely can. It gives you all of the protection of Ceramic that vastly out performs wax and all of the labor, maintenance, and time spent that waxing entails. So if you just like rubbing your truck with wax, you can keep doing it. Does it extend the life of the ceramic? Maybe by a few months. Is it as good as misting with CMX or similar after a wash? No.
  2. Nov 16, 2024 at 9:35 AM
    #42
    MGMDesertTaco
  3. Nov 16, 2024 at 5:25 PM
    #43
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Ok, let me know how that works out for you. Especially, with all the paint problems listed on this site. My insight comes from 30+ years in the collision repair industry. Ski
    VaToy likes this.
  4. Nov 16, 2024 at 5:53 PM
    #44
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have been a detailer for 40 years as a side business and have used all the sealants that have come and gone over the years. Ceramic is good but if you're having to add a touch up detail spray every few months your Ceramic is not holding up and your just adding shine and hydroponics to the finish. I have used a German Ceramic coating infused with Graphene for 6 years and reflash it every 16 to 24 months on my own vehicles and the finish is near flawless.
    If wish they still made a decent Acrylic Teflon paint sealant like they did in the 80s and 90s as that stuff was amazing and lasted a good 2 years and I would put it against any Ceramic today as far as protection. This stuff was long before detail sprays.
  5. Nov 16, 2024 at 7:11 PM
    #45
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    What is the name of the German Ceramic coating you are using?
  6. Nov 16, 2024 at 7:26 PM
    #46
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    well consider my 2011 has been holding up well given that it lives outside 24/7. :thumbsup:
  7. Nov 16, 2024 at 7:46 PM
    #47
    skidooboy
    central lower mich
    But, have you polished it every year? or multiple times? That is what I am getting at. If a person polishes their auto with even a mildly abrasive corrective polish, or pad several times... They are thinning the clear coat, which is your UV protection. Over time, this will create a thin clear coat issue. Yes, you can polish through and "burn" the clear through to the base (color) coat. Ski
    VaToy likes this.
  8. Nov 17, 2024 at 6:41 AM
    #48
    BillyE
    BillyE Well-Known Member
  9. Nov 17, 2024 at 7:20 AM
    #49
    ace96
    Western KY
    every couple of years. Only when it’s time to apply new coating. Quite aware of you can burn through paint. Less like with orbital versus a rotary.
  10. Nov 17, 2024 at 12:35 PM
    #50
    VaToy
    Parts Unknown
    IDK what happened, I will try later when I get home
  11. Nov 17, 2024 at 12:38 PM
    #51
    VaToy
    Parts Unknown
  12. Nov 17, 2024 at 1:42 PM
    #52
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I don't understand . . . . . you wax your truck ?. . . . . why?
  13. Nov 17, 2024 at 3:40 PM
    #53
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Genuinely curious; why not just say what you use? Seems easier than searching, copying the link, posting...then searching, copying the link and posting again when the first one doesn't work...
    But, on that note, your second link also doesn't work.. :anonymous:
    Edit: it did the second time I clicked it. The first time just brought up a white blank page. And for anyone in the future when the bing link invariably breaks, it's "KISHO Si-901" and the direct link is: https://www.kisho-coating.com/kisho...cs-glass-coating/germany-ceramic-coating.html
    Vitamins likes this.
  14. Nov 17, 2024 at 4:05 PM
    #54
    VaToy
    Parts Unknown
    I get a commercial unbranded coating for my business from them and you wouldn't be able to buy it unless your a commercial buyer from the distributer. Also they don't have the coating I used 6 years ago. The company upgraded it with a name change so it would have been pointless to just give the name. I have used about 5 different types for customers and this one proves to be the best with zero issues and the longevity is pretty good.
  15. Nov 17, 2024 at 6:06 PM
    #55
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Thanks for the clarification. So to disambiguate a bit - this is "closest that's available to the unwashed masses" to what you applied 6(!) years ago to your personal vehicle; but you have used the linked "KISHO Si-901" on customer vehicle(s), and seems to be..well, to add some ambiguity back, 'almost' as good? Say you weren't a commercial detailer anymore, this is at least one you'd consider to use for yourself?
  16. Nov 17, 2024 at 6:23 PM
    #56
    ace96
    Western KY
    MagicToolbox likes this.
  17. Nov 17, 2024 at 11:07 PM
    #57
    VaToy
    Parts Unknown
    Thats what I use for my vehicles and customers vehicles. I was sent a few sample kits to try. Thats how I found out of the product. There are others that I'm sure are good but this product serves me well.
  18. Nov 18, 2024 at 7:31 AM
    #58
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I avoid putting it on stuff that would normally not wax. Like rubber & Plastic trim.
    I do use it on glass roofs and windows - including the windshield. (No need for wipers!).
  19. Nov 18, 2024 at 7:41 AM
    #59
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
  20. Nov 18, 2024 at 8:03 AM
    #60
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I use this it’s rock solid and as others have said CG is losing its game. I was a solid CG user for yrs and agree the quality has went down I have jumped over Groits.
