best way of wiring and routing 4 Aux lights on 1st gen roof?
Discussion in 'Lighting' started by NotstockTRD, Nov 16, 2009.
  1. Nov 16, 2009 at 6:42 PM
    NotstockTRD
    NotstockTRD [OP] TRD
    st louis
    99 TRD Prerunner V6 with many mods..
    Shitloads
    any write ups out there?
    any ideas on the cleanest looking way to do this?
    run to a seperate small battery?
    thanks in advance fellas...
    __________________
    TRD
  2. Nov 16, 2009 at 7:21 PM
    NotstockTRD
    st louis
    Shitloads
  3. Nov 16, 2009 at 7:22 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Wondering the same thing...
  4. Nov 16, 2009 at 7:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  5. Nov 16, 2009 at 7:28 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    I have my 4 PIAA's mounted on my roof rack but I have yet to decide how to wire them up? Right now they are wired so that the outer 2 will come on separately than the inner two. My only question is how to power them... I don't want to be sucking my battery dead every time I turn them on.
  6. Nov 16, 2009 at 7:39 PM
    NotstockTRD
    st louis
    Shitloads
    i just ordered one and im trying to figure out how and where i will route the wires? drill into the roof-seems to be the only option i can think of?
  7. Nov 17, 2009 at 2:27 PM
    NotstockTRD
    st louis
    Shitloads
  8. Nov 17, 2009 at 3:01 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Oh jeez. It's a nightmare.
    I love lights, but I hate wiring them. I have quite a lot of electrical knowledge, but it's still a bitch.
    By the time I am done with my truck, I want to have 13 total aux lights, which means i need at least 7 switches and a nightmare of wiring.
    Right now I only have 3 driving lights, 2 fogs, and 2 reverse mounted, but will soon put on a roof rack with 2 PIAA's and 2 bed lights.
    I don't think you need to drill any holes...any visible ones at least.
    I did not drill any holes through the firewall from the battery to the switches. I just ran the wires through the gap between the fender and the body, and ran the wires through my weatherstripping to my switches. I looks like any light bar or rack you'll get will have to be clamped onto the door, under the weatherstripping, so you should just run it right under the weatherstripping right to your console.
    Seems even easier than all the wiring I did for my front lights or my reverse lights.
    I'll do a writeup/build thread for my truck soon, where pics will be taken. :D
  9. Nov 17, 2009 at 3:09 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    MY only real question/concern is how to power them? Do I run the switches straight off the battery with an inline fuse or straight from the fuse box...?
  10. Nov 17, 2009 at 3:13 PM
    sachou
    Sam
    I ran them straight from the battery, and just used crimp connectors to hook up 15 amp fuses to each wire, then wired up to the dash, where I have my switches.
    If you're only doing like a pair of lights, I geuss you could find an unused, but still wired up fuse on the fusebox, but I don't know if I'd wanna take apart the fusebox to do that...
    I have all the fuses labeled and sitting right next to the fusebox. Kind of messy, but it works.
    EDIT: Rule of thumb is to make sure the wire gauge is appropriate for the light, and the fuse is appropriate for the wire gauge.
    http://www.rbeelectronics.com/wtable.htm
    ^^that chart's pretty useful.
  11. Nov 17, 2009 at 3:23 PM
    sachou
    Sam
    As far as power usage, 10 of the 13 lights I'm installing will pull 55 watts each, while the other 3 will pull 100 watts each. Giving me a total power consumption of more than 800 watts, compared to the 100 watt pull of just the headlights. Combined with my 300 watt amp makes this a lot of fucking power to pull from one little battery!
    I believe that our alternators are 130 amp ones, multiplied by 12 volts makes that 1560 watts of alternator output.
    I'm going to be putting in a secondary marine deep cycle battery in the engine bay eventually. If you'll need a second battery, that depends on how obsessed you are with lights. ^_^. You could be good using a better battery, or my friend starts his giant (454, i think? who cares, it's way too big) chevy off of one sears deep cycle battery.
    I'm ranting. I need to do my homework. Somebody please stop me.
  12. Nov 17, 2009 at 3:31 PM
    NotstockTRD
    st louis
    Shitloads
    i might just have a mechanic do the dirty work...:D
  13. Nov 17, 2009 at 3:53 PM
    sachou
    Sam
    Let me know how much that costs. I'd like to know how much money I'm saving if I ever feel like giving up.
  14. Nov 17, 2009 at 8:10 PM
    NotstockTRD
    st louis
    Shitloads
    who has a freaking writeup? WTF!!:D
  15. Nov 17, 2009 at 10:51 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    have you tried running the wires under the windshield weatherstrip, some people have done that. the nice light racks that i have seen on the roof are drilled through the roof and enclosed professionally. not cheap
  16. Nov 18, 2009 at 12:08 PM
    sachou
    Sam
    Oh wait, nevermind. Our alternators put out only 70 amps...giving us only 840 watts...jeez I might need a bigger alternator.
    EDIT: Anybody try a Cadillac Deville alternator swap?
  17. Nov 19, 2009 at 12:01 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if you had a bar that mounted in the bed and shined the light over the top of the cab, you could just run the wires under the truck up to the engine bay and through the firewall.
  18. Nov 19, 2009 at 4:46 PM
    sachou
    Sam
    Yeah, kind of thought of a rollbar, but that'd be a lil expensive, and I haven't seen many on Tacomas.
  19. Nov 27, 2009 at 8:59 PM
    NotstockTRD
    st louis
    Shitloads
    I ran the wires through the door weather strip... pain in the asssss install
    but i like the final outcome...
  20. Dec 7, 2009 at 10:34 PM
    NotstockTRD
    st louis
    Shitloads
