Best Way to add lift to a 6 inch kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rawdog03, Mar 9, 2021.
  1. Mar 9, 2021 at 9:50 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just put 44 inch tires on.
  2. Mar 10, 2021 at 5:10 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Being new to the truck scene and planning such a radical lift is a recipe for disaster. Doing such an aggressive lift will require major re-engineering. Unless you have an engineering degree AND have a substantial bankroll, going this route will yield unacceptable results. Honestly, this is the wrong vehicle do do such a lift.
    If you do manage to accomplish this, it's highly unlikely that you'll be happy with it. Drive-ability, reliability, and safety will be significantly compromised. In a nutshell, don't do it......
    Shawner1974 likes this.
  3. Mar 10, 2021 at 5:23 AM
    Shawner1974
    Shawner1974 Well-Known Member
    Shawn
    CNY
    2012 Base Tacoma 2.7. 5 spd Regular Cab
    Definitely this. By the time you factor in new driveshafts and all the front end work (worn joints, bearings and such) , plus re-gearing for larger tires (which should be done, but some fools don't) it's one expensive project. Don't forget to re-aim your headlights, and, depending on your location, drop bumpers to remain legal. I have built several lifted mud beasts in my younger days...always older leaf spring rigs or Ford coil springers. Jacked em up as much as 12". As I have grown older I have gotten (somewhat) wiser. If I were to do it all over, I would whack the fenders as much as possible and lift as little as needed to clear the tires. Still need to regear though. And no...no cold air intake or super exhaust or fancy tune will make up for the power lost with bigger tires...re-gearing is the only way, and it costs $$$
    Crow Horse[QUOTED] likes this.
  4. Mar 10, 2021 at 5:47 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Addendum - Vehicles generally speaking are designed with reliability and safety as priorities. Each "system" on a vehicle must operate in "harmony" with the other systems. Once you exceed the design parameters of a particular system, you in effect create an out of balance condition where you have created weak links in the vehicle. There's a ripple effect and every system on the vehicle will be effected. For instance, huge tires will require suspension changes, leading to possible axle changes, brake changes, steering changes, drivetrain changes, etc., etc.. That's the short list.
    There's one more variable in this equation. If you are able to accomplish this lift, consider the changes you'll have to make driving it. It's not going to handle like a sports car and shouldn't be driven as such. It'll be a completely different animal and needs to be driven within it's performance envelope. This usually is a huge compromise.....
