Best way to address Tacoma lean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, May 16, 2019.
  1. Nov 4, 2019 at 5:40 PM
    DNAVES
    DNAVES Active Member
    Abraham
    95' 2.7L 4x4
    Did you end up figuring this out?
  2. Nov 5, 2019 at 9:14 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    X2
  3. Nov 5, 2019 at 9:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Do you have 3 leafs or 4 on each side? If 3, start by getting the free 4 leaf packs from the recall at a dealership. Should have 4 leafs and 6 clips/retainers on each set on each side. Then see whatcha got. IMO, half a tank of gas to do measurements because truck is closer to half more often than full. But I guess if you measure with full tank then it'll account for driver weight to some degree. I would start with rr leafs then see what you got up front after that. Then go for the 1/4" top hat spacer if 1/2" off up front from hub to fender.
  4. Nov 5, 2019 at 10:54 AM
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    Don't mean to thread jack, but I have same problem. Driver side from center hub to fender is 22", passenger is 23". I have 5100's all around set to 0. Should I raise the driver's side ones up to correct this?
  5. Nov 5, 2019 at 12:22 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    no, buy the half inch spacer.
    SocalTaco15 likes this.
  6. Nov 5, 2019 at 3:47 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I usually cavort around with 6 gallons(milk crate) of water behind the passenger seat and a solar power battery behind the rear wheel well, levels it out pretty well. It is noticeable, for sure.
