BEST WAY TO CHANGE COOLANT?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shiftmx731, Mar 11, 2013.
  1. Mar 11, 2013 at 11:51 AM
    shiftmx731
    shiftmx731 [OP] New Member
    06 PreRunner
    Bilstein 5100s
    Im nearing 100k miles on my 2006 Toyota Tacoma V6 Prerunner and want to change the coolant as required in the maintenance schedule. Whats the best way to do this?
    Ive read to flush with distilled water? Not to flush with distilled water? Drain and flush with just collant? Drain just the radiator? Drain the radiator plus the engine? Lots of mixed messages.
    Can someone please explain the best way to go about servicing? Much appreciated!!!!!
  2. Mar 11, 2013 at 12:26 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I always just empty, fill w/ distilled water, run the heater on high for 10-15 min, drain again, and fill w/ correct mix of collant / water.
  3. Mar 11, 2013 at 5:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
