Best way to cut corrugated aluminum
Discussion in 'Garage / Workshop' started by coffeesnob, May 30, 2012.
  1. May 30, 2012 at 11:59 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    What is the easiest way to cut corrugated Al sheeting? Disc grinder?
  2. May 30, 2012 at 12:00 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Demo saws work well depending on how clean the cut needs to be. Otherwise, disc grinder as you mentioned.
  3. May 30, 2012 at 12:01 PM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Circular Saw with metal cutting blade? Add a 2x4 for a flat guide surface?
  4. May 30, 2012 at 12:07 PM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    turn your saw blade backwards and use circular saw. Always worked good for me.
    No wait, that was tin roofing. Never tried on corrugated.
  5. May 30, 2012 at 12:11 PM
    medusa1066
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    I know, I am sure this is tough stuff. Circular saw would give you a nice straight line
  6. May 30, 2012 at 12:24 PM
    Pugga
    Massachusetts
    F-150 Mod
    That works really well for plexi, never tried it on aluminum.
  7. May 30, 2012 at 1:54 PM
    OnTheTrail
    OnTheTrail Well-Known Member
    San Jose, CA
    2006 TRD Offroad
    This. Get a metal blade that has square teeth instead of pionted teeth. It will be labled for cutting metal. It's super loud and shoots debris right at your eyes so get a face shield.
  8. May 30, 2012 at 4:22 PM
    coffeesnob
    VA
    ok all thanks!
  9. May 30, 2012 at 4:25 PM
    TheSloth
    TheSloth Well-Known Member
    David
    Clemmons, NC
    '05 Tacoma Stock
    Thule 422xt Xsporter Rack
    Depends on thickness of aluminum sheet - if it's only .016 to .030 just a pair of metal snips would work fine
  10. Jun 3, 2012 at 12:49 AM
    singlefin
    singlefin Well-Known Member
    Portland, OR
    Syncro
    That's how we cut my corrugated SS roofing, worked perfect cutting 4 sheets at once.
  11. Jun 3, 2012 at 9:57 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Stainless roofing ? Very nice
    How is it appled ? True standing seam ?
  12. Jun 3, 2012 at 9:23 PM
    singlefin
    Portland, OR
    Syncro
    Ooops, not SS I don't know why I typed that...it's galvanized. I used self tapping screws that have a rubber washer, the panels overlap each other.
  13. Jun 3, 2012 at 9:24 PM
    OZ-T
    Peter North
    British Columbia
    Oooooooh
    Not as excited anymore
