"Best Way to Depressurize the Fuel System"
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJunkie8691, Mar 19, 2022.
  1. Mar 19, 2022 at 4:55 PM
    TacomaJunkie8691
    TacomaJunkie8691 [OP] 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Hello Everybody,
    What is the best way to depressurize the fuel system on a 1999 Toyota Tacoma with the 3.4 V6?
    Thank you in advance for all of your replies.
    Take care,
    Paul Muzinich
  2. Mar 19, 2022 at 5:57 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Open the gas cap and open a fuel line, say at the fuel filter or fuel rail.
    TacomaJunkie8691[OP] likes this.
  3. Mar 19, 2022 at 7:04 PM
    Madjik_Man
    Colorado Front Range
    Remove the fuel pump relay (lower dash). Then start the truck until it dies.
    There will still be a tiny bit of pressure in the system so go slow when undoing the first flare nut.
  4. Mar 19, 2022 at 7:25 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    The method outlined by @Madjik_Man is technically the correct way to depressurize the system. If, however, what you are doing is replacing the fuel filter, I've found that you don't need to go to the trouble of depressurizing the system before removing the filter. Rather, if you go slowly when undoing the first flare nut, cracking it just enough for fuel to drip from the filter into a catch basin, you can just let the system depressurize itself prior to completely removing the filter.
    Here's a step-by-step tutorial I put together on that process, with pics, parts, and tools needed to do the job.
    How-to: Replace the Fuel Filter in a 96-04 Tacoma or 96-02 4Runner
  5. Mar 20, 2022 at 2:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have always done it like this
