Best way to disable ABS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChrisMassy99, Dec 28, 2016.
  1. Feb 9, 2017 at 9:32 AM
    #41
    BahiaTaco
    BahiaTaco Active Member
    Timo
    Los Angeles
    15 Prerunner SR5
    SnugTop Topper Ride Rite Bags Air Lift Compressor Yakima Roof Rack Skidplate Ultra Gauge Side steps TRD off-road wheels
    Cool. Opinions are fine but not very convincing. If anybody cares to explain why, I would be really interested.
  2. Feb 9, 2017 at 9:36 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Adapt. Don't be a passenger behind the wheel.
    02Duck likes this.
  3. Feb 9, 2017 at 9:37 AM
    #43
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ABS increases stopping distances on all low traction surfaces , thats not an opinion
  4. Feb 9, 2017 at 9:42 AM
    #44
    DrFunker
    DrFunker Well-Known Member
    One winter while pulling into my icy driveway at low speed, I bounced my wives car about 5 feet from where she had parked due to the ABS kicking in. The driveway was not an ice rink, it just had patches of hard pack snow that were slippery.
    That spring I installed the kill switch.
    Also had a friend that "slid" into a busy street from a parking lot because the ABS kicked on.
    There are times it is good and times it is dangerous, imo.
    TDHofstetter likes this.
  5. Feb 9, 2017 at 9:42 AM
    #45
    OZ-T
    Peter North
    British Columbia
  6. Feb 9, 2017 at 1:06 PM
    #46
    BahiaTaco
    Timo
    Los Angeles
    15 Prerunner SR5
    If it's not an opinion then there should be a logical reason why ABS increases stopping distances. Why would it increase it? All it does is prevent a wheel from locking up. And a locked wheel has less braking power than a wheel that still rotates close to the locking point. Except on loose surfaces like gravel or deep snow.
  7. Feb 9, 2017 at 1:32 PM
    #47
    OZ-T
    Peter North
    British Columbia
    Lots of info online if you are interested but here is a quick primer
    https://www.tc.gc.ca/eng/motorvehiclesafety/tp-tp13082-abs2_e-215.htm#is
  8. Feb 9, 2017 at 1:42 PM
    #48
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
  9. Feb 9, 2017 at 1:57 PM
    #49
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    you are not completely wrong with this statement, but I feel the ABS system, when it allows the wheel to continue spinning to prevent it from locking it up, it isn't as close to the locking point as it could be. when I'm applying the brake I can feel how hard i can apply the brake before the wheels lock up. so in certain scenarios I can brake and keep it closer to the locking point then the abs system, which if accomplished correctly, since I'm applying more brake then the abs system without locking up the wheel, I will stop sooner.
  10. Feb 9, 2017 at 2:11 PM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Threshold braking
    Bocsy44 likes this.
  11. Feb 9, 2017 at 2:13 PM
    #51
    BahiaTaco
    Timo
    Los Angeles
    15 Prerunner SR5
    Thanks for the link. "on dry or wet roads...will be about the same as without ABS"...."...longer....on gravel, slush and snow". That's exactly what I said - what they call the "plow" on loose surfaces I called a "wedge". This does not support that braking distances will increase on slippery surfaces.
  12. Feb 9, 2017 at 2:23 PM
    #52
    BahiaTaco
    Timo
    Los Angeles
    15 Prerunner SR5
    Exactly - if you can brake perfectly at the threshold, you don't need ABS at all, and it will never kick in. ABS only kicks in if one of your wheels goes beyond the threshold and starts locking up. And if you are on a loose surface, braking beyond the threshold will create the wedge and stop you faster than braking at the threshold. Therefore ABS can result in longer straight line stopping distances on loose surfaces.
  13. Feb 9, 2017 at 2:47 PM
    #53
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    Unfortunately for me, I tried the abs kill switch mod and the switch wouldn't work... and just to test it I disconnected the wires from the back of the switch I installed knowing it would fail, and it still wouldn't deactivate abs....
    So I'm guessing the light green wire I'd not the abs wire on my truck : /
  14. Feb 9, 2017 at 2:54 PM
    #54
    DrFunker
    I see you have a Prerunner. May be different wiring for you.
  15. Feb 9, 2017 at 2:55 PM
    #55
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    That's what I was thinking, but after scouring the OP I couldn't find any talk of it
  16. Feb 9, 2017 at 3:13 PM
    #56
    OZ-T
    Peter North
    British Columbia
    K
    Good luck with that
    Torspd likes this.
  17. Feb 9, 2017 at 3:15 PM
    #57
    Pigpen
    Dan
    Northwest Montana
    Kids...
  18. Feb 9, 2017 at 3:15 PM
    #58
    OZ-T
    Peter North
    British Columbia
    Is there an echo in here ?
    Thats exactly what I said
    Torspd and IronPeak like this.
  19. Feb 9, 2017 at 3:36 PM
    #59
    BadlandsTACO
    BadlandsTACO Captain Quarantine
    '13 TRD Sport DCSB
    Done: TRD Pro Skid, TRD Pro Grille Insert, Husky X-Act Liners, Clazzio Seat Covers, UNI Filter Mod, 2nd Gen TRD Pro Suspension, Wheelers 1.5" AAL, 17" SCS SR8 (Gunmetal), Falken Wildpeak AT3W 265/70/17, Amber Morimoto XB LED Fogs.
    Looked like the guy was running the exact same vehicle for both scenarios in the vid. From what I gathered the point was break sooner, with more ease, stop faster. It's not rocket science on snow/ice... I have no experience off road.
