best way to do a ATF drain & fill
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Nov 22, 2010.
  1. Nov 22, 2010 at 11:25 AM
    ywen
    ywen [OP] Well-Known Member
    My understanding that the AT has a very narrow tolerance of acceptable fluid level.
    When I'm adding the ATF via the dipstick hole, how soon after does the fluid show properly on the dipstick? Can I just let the fluid settle down and then check the COOL range on the dipstick? Or do I have to start it up and shift thru all the gears before checking?
    For some reason I feel very nervous about replacing the ATF, unlike changing the engine oil, I feel that if I screw up with the ATF, even subtle differences from the recommended level will f up the tranny..
  2. Nov 22, 2010 at 11:27 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    You must shift through all of the gears and check the fluid while the engine is idling in park. It's not that bad, just add a little at a time til you get it right.
  3. Nov 22, 2010 at 11:29 AM
    ywen
    Right but how soon after pouring in the fluid, will the new fluid indicate on the dip stick?
    Also whenever I'm adding a little bit new fluid, do I need to re-shift in order to check to new level?
  4. Nov 22, 2010 at 11:50 AM
    JDMcQ
    I gauged how much I took out and added a bit less than that back in before I began checking, I believe that after the initial shift through, one can just check the level while the engine is running.
