best way to do small lift on tacoma
Discussion in 'Suspension' started by reggie1234, Apr 23, 2013.
  1. Apr 23, 2013 at 1:52 PM
    reggie1234
    reggie1234 [OP] Member
    either getting 2013 tacoma sport 4 door with long bed or 2014 when they come out. and i want to do a mild lift/ leveling kit, not sure what are good ways to do it, was thinking of the bilstein 5100 adjustables. i would want enough room for 33 inch tires or so. truck is used for everyday driving and on the beach with surfboards. trading in my fj cruiser which was great.
  2. Apr 23, 2013 at 1:54 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
  3. Apr 23, 2013 at 1:57 PM
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
    Yeah the billies 5100's adjustables you can have the 33's tires installed. Good luck man. :thumbsup:
  4. Apr 23, 2013 at 3:36 PM
    reggie1234
    thanks will i have to change or add anything else with the bilstein 5100 adjustables. are there other systems that i should check out
  5. Apr 23, 2013 at 3:53 PM
    choppersx
    Frank
    SoCal
    1968 Ford Mustang
    Yeah theres plenty of lifts you can check here on different threads buts its all depends on what height you looking for, i have my billies set at 1.75 on the front with the ICON 3 leaf pack add on (1.5 inch) which adds to the back leaf springs without TSB.
  6. Apr 24, 2013 at 7:20 AM
    reggie1234
    thanks for the reply. You didn't want to lift to 2.5 on the front
  7. Apr 24, 2013 at 7:46 AM
    choppersx
    Frank
    SoCal
    1968 Ford Mustang
    I had the choice but i didnt change my coils i left them stock and it rides good. Also i heard some of the guys here once you go 2.5 lift would also need to replace the UCA's (Upper Control Arms) so didnt want to take the risk. Im happy with my lift , its my daily driver and for off-roading well the most would do its when i go camping or hiking.
  8. Apr 24, 2013 at 7:49 AM
    ScTuna
    ScTuna Well-Known Member
    Texas
    2016 Tacoma
    If you like warranty get the Baja series Tacoma.
  9. Apr 24, 2013 at 7:52 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    33s probably aren't going to fit with 1.5" of lift unless a lot of trimming is done. 33s rub on 2.5"-3" lifted tacomas. 32s would probably be a better choice. I'd go with some 265/75/16 if you have a 16" rim or I believe 265/70/17 for a 17" rim.
    Glad you are thinking about 5100s to gain lift instead of coil spacers :thumbsup:
  10. Apr 24, 2013 at 8:01 AM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    I have this same setup and it's a smooth ride. Kept my factory coils and have the non-tsb leaf packs.
  11. Apr 24, 2013 at 8:07 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    On my 2012 got 5100 all around set at 2.50 with 1.50 aal going to burn out the stock 265 tires and get 285 after
  12. Apr 24, 2013 at 1:53 PM
    reggie1234
    zboy did u have to change uca's when at 2.5 and will 285 fit. also if you put the bilsteins in rear as well doesnt that add up to 1 inch lift instead of aal
  13. Apr 24, 2013 at 2:06 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Rear bilsteins dont add lift. Add a leaf, blocks or a new leaf pack will lift the rear end. UCAs are recomended for 2.5" or more to help get alignment in spec. Expect to trim with 285s, maybe even the cab mount chop. You need wheel spacers to run 285s on stock wheels or aftermarket wheels with 0 to -12 offset
  14. Apr 25, 2013 at 3:37 AM
    DevL
    DevL Well-Known Member
    A standard lift of 0-3" will not effect what tires fit or do not fit. The exact same trimming needs to be done to a stock Tacoma as one with a lift. THe lift only changes how much compression of the suspension causes the same rubbing.
    33" tires will fit on no lift, 1.5" lift, and 3" lift exactly the same and all require the same trimming to get the 33" tires to fit.
  15. Apr 25, 2013 at 7:39 AM
    zboy
    Oahu808
    12 TRD OR
    4 wheel parts did the work no UCAs alignment good (4) 5100 (2) AAL installed with alignment & labor $800.00
  16. Apr 25, 2013 at 7:58 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    It seems like this has been an ongoing thing. I run 285/75/16 KM2's on billies @ 2.5" & progressive AAL on the rear with no issues. Like I have said many times before, this truck see's 90% pavement with very limited wheeling. I have had zero rubbing issues. I do agree with your statement on the lift only changing how much more compression is required to get back to the point that the tire will rub when wheeling these trucks. But telling people that don't wheel their trucks that 33's will rub and require trimming regardless of their setups is not really true. Sorry to clog this thread OP.
  17. Apr 28, 2013 at 10:31 AM
    DevL
    I rub the same off-road as on. I turn into a steep driveway entrance at speed and compress the suspension to the point of rubbing. I hit undulating pavement at speed and get rubbing. The vast majority of my rubbing testing was done on pavement and was done pulling into parking lots with some speed. This causes the same rubbing in the same areas as offroading. No amount of rubbing should be accepted on or off road. This concept of lift clearing tires I heard here caused me to almost tear off my front bumper while onroad, tear off my rear fender off road and damaged my tires on road. I stand by my statement. On road you have greater wheel speeds that can result on more damage. It is unethical to put people's property at risk by repeating the lie that lifts make room for larger tires.
  18. Apr 28, 2013 at 10:44 AM
    Boone
    Boone, NC
    Airbags deployed
    First off, I am not doing anything "unethical" or "repeating lies" by telling people of my exact setup and how it works for me. All I have done in any previous post is let people know that I do not have any rubbing issues on-road or the minimal off-road use that this truck sees. You may want to go back and look at some older posts. I f you do in fact find one that I state "lifts make room for larger tires" I will concede. The offer still stands, if at any point in time you are near Boone, North Carolina you can come see the truck for yourself. If you are within a reasonable distance of Boone at any time I'll even come meet you to give you a chance to critique my truck.
    If you care to take this to PM's as to not clog another members thread, feel free to do so.
    Once again, sorry to clog your thread with this OP.
