Best Way to Earse CEL History
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jul 29, 2024.
  1. Jul 29, 2024 at 8:30 AM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Other day i was doing alot highway driving and got about 16 miles per gallon. This is bad mileage for my vehicle.
    I have a cheap scanner i usually clear O2 CEL with and usually can go 300-400 miles on one tank without another CEL coming on.
    Yesterday I pulled ECU fuse out for 10 min and put back in started engine back up and CEL was still on. Not really sure how thats possible but it happened.
    So what is best way to clear not just light but entire history from the computer ?
  2. Jul 29, 2024 at 9:43 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    might be a "hard code" and cant be cleared...what code is it giving?
    Dm93 likes this.
  3. Jul 29, 2024 at 9:49 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What code(s) is it setting?
    Unhooking the battery clears codes and adaptives but it's not gona fix your problem.
    Need to see what code(s) it's setting to know what to start looking at.
  4. Jul 29, 2024 at 10:13 AM
    TacoBell07
    Four door 2wd Taco
    As a test I unhooked the MAF sensor (easy to get to) and then took out the ECU fuse in the fuse box next to the battery, so in my test it set off some MAF codes not sure which exactly. However the code it keeps throwing is P0420 and i think its because theres a downstream O2 sensor that has a dent in the shell that the wires go into.
    So in general is unhooking the battery better way than taking ECU fuse out ? Because now i almost want to unhook the main connectors from the computer and just leave it unpluged over night in case theres a capacitor or something that needs to completely drain to reset everything.
  5. Jul 29, 2024 at 10:28 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I believe if you want to truly clear it out, you need to disconnect BOTH battery connections and hold them together for...????10-20min???
    like so....
    TacoBell07[OP] likes this.
  6. Jul 29, 2024 at 10:59 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Providing there are no exhaust leaks near or upstream of the AFR and O2 sensors 95% of the time a P0420/P0430 is a failed catyletic converter.
    Need to verify the AFR and O2 sensors are working properly but odds are it's the converter.
    https://youtu.be/Oivzxq_RuAk?si=3MbB_g4tSDOIikQH
    Unhooking power from the PCM wheather pulling the fuse or unhooking the battery clears codes and all adaptive memory.
  7. Jul 29, 2024 at 11:05 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    If your scanner use to be able to clear the code but now can't most likely the problem has gotten so bad that it is immediately causing a problem when you start the truck back up. Time to actually fix the problem.
    3JOH22A likes this.
  8. Jul 29, 2024 at 11:07 AM
    TacoBell07
    Four door 2wd Taco
    Yes, my CATs got removed all 4 of them. Im using sprak plug foulers to try to keep light from coming on at first it worked but then i noticed it came back and then i noticed the upper part of the downstream sensor had a dent in it right near where the wiring converges and goes into the O2 sensor.
  9. Jul 29, 2024 at 11:15 AM
    gstodd
    2005 2wd base 5-lug
    Are you running anit-foulers on both the upstream and down steam O2 sensors or just the downstream? Should only be on the downstream. If you have it only on the downstream then you might need to replace the O2 with the dent, may be a pinched wire. I'd try having it scanned with a better scanner with live data to see what exactly is going on with the O2 voltages.
  10. Aug 1, 2024 at 10:20 PM
    TacoBell07
    Four door 2wd Taco
    I unhooked the MAF sensor and made sure code was on.
    Took and put a wire onto the battery cables (with the cables disconnected of course). Let it sit unhooked up to cables for several hours and then reconnected the battery and the MAF related code I triggered on purpose was gone. At the very least it cleared the code as good as my basic code scanner does. Will update after drive a good distance if the gas MPG is back to normal and there still no codes.
    bkhlrTaco's[QUOTED] likes this.
