Best way to feed wire through your firewall
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mricha330, Jul 13, 2019.
  1. Jul 13, 2019 at 6:21 AM
    mricha330
    mricha330 [OP] Well-Known Member
    Colorado
    Just looking for opinions. For all of you who have installed ditch lights, light bars etc how did you run the wire through the firewall to a switch in the cabin? Did you use any kind of fish tape?
  2. Jul 13, 2019 at 6:27 AM
    ICU1
    ICU1 Well-Known Member
    Coat hanger
  3. Jul 13, 2019 at 6:29 AM
    JonesMGMOR
    JonesMGMOR Well-Known Member
    North Georgia
    2018 Tacoma TRD OR
    Prinsu Roof Rack Mictuning Rock Lights 8ct Mictuning 32” light bar Caliraisedled Ditch Lights Caliraisedled TRD Pro Grille Calirqisedled rear Amber pod lights Baja Designs s2 sport pod lights Eibach pro truck lift stage 1 OME Heavy duty leaf springs JBA upper control arms Smittybilt X20. Winch Smittybilt RTT SSO front bumper
    I cut a hole in the boot. You can seal it but if you plan on running more wires in the future just leave it be. It’s not really an issue. Just make a small incision and squeeze the wires through with a coat hanger. It stretches. :cheers:
  4. Jul 13, 2019 at 6:30 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    There's a rubber grommet/hole on the driver side where some wires were already fished thru, i just took a metal hanger and made the hole a little bigger and used that as a pipeline for other wires, careful not to damage any of the other wiring
    mricha330[OP] and rnish like this.
  5. Jul 13, 2019 at 6:30 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    No need to cut, bend a coat hanger straight and tape it to that. Push through about two inches and then pull from cabin side.
    Tullie D and mricha330[OP] like this.
  6. Jul 13, 2019 at 6:33 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I didn’t use a coat hanger, its a short run. Guess it depends on the gauge of wire. I sprayed everything with windex and pushed it through the grommet, pulled it from the other side.
    mricha330[OP] likes this.
  7. Jul 13, 2019 at 9:39 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
